Quote Originally Posted by burgundybullet View Post
Because you are not using the constant power it doesnt have time to cycle in the time it blinks. I considered those for my mirror project but got to thinking that the blinking signal would be a problem. My only guess is that you have to find the wire from the signal stick before it gets to the relay I believe (Think its a relay that makes the signal blink). Once you find that constant wire you will need to run your power from that and then find a constant ground would be my best guess.
Does this make sense?
You are correct, in order for the sequential to function properly it will require a power source that gives it enough time to cycle.
-Nick C.
