Thread: Where is rear defogger relay wire? (and trunk relay wire)
Results 1 to 20 of 23
  1. #1 Where is rear defogger relay wire? (and trunk relay wire)
    Donating Users kind153's Avatar
    Pittsburg, KS
    Trying to install viper 5701.. found all wires but rear defogger and trunk relay wire.
    the12volt.com's diagram says to get it from the switch, but I hear a relay clicking when I push trunk release button on my factory fob. (not when I push button)
    and a wire from HVAC control controls rear defog? relay?
    I want relay wires........
    anyone?
    Thanks,
  2. #2 Re: Where is rear defogger wire?
    Wichita
    Isn't that clipped right into the rear window? LH & RH sides?
  3. #3 Re: Where is rear defogger wire?
    Pittsburg, KS
    Quote Originally Posted by echarleswhyte View Post
    usually they are clipped on the window like mentioned above, LH and RH
    Sorry,, I didn't ask precisely.
    Where is the wire that goes to the relay of rear fogger??
    Thanks!
  4. #4 Re: Where is rear defogger wire?
    canada
  5. #5 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Wichita
    Check your fuse box under the hood & in the glove compartment.
  6. #6 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    ok,, and what am I looking for there?
  7. #7 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Wichita
    Quote Originally Posted by kind153 View Post
    Hmm. If your not sure what your looking for get a Chilton manual. See if the wiring diagrams etc. help.
  8. #8 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    Got the manual, but can't find the diagram I need.. any clue?
  9. #9 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    nobody?????????
  10. #10 Re: Where is rear defogger relay wire? (and trunk relay wire)
    You don't know what you're looking for at ALL do you...
    Relay = switch so what wire of the relay are you looking for?
  11. #11 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    Relay != switch.
    I look for the wire that triggers the relay that clicks when I push defog button on hvac.
    (and yes, the trunk release button on my factory fob too.)
  12. #12 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Wichita
    All your fuses & all your bulbs are good? You've checked your wiring to the defogger? Hmm. . . idk
  13. #13 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    ya it works, i just want to hook it up to my viper module; which isn't supposed to be connected directly to solenoid; only to relay.....
  14. #14 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Wichita
    Have you tried hooking up your Viper system yet to see what happens???
  15. #15 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    I've seen too many stuff dead in front of me to try to hook it up to the solenoid. -_-
    nobody has the diagram?? come on I know there's someone!
  16. #16 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    nobody?? really?
  17. #17 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Michigan
    If you remove the plastic panels and the metal panel below the steering wheel(knee bolster) you will see 3 relays to the left of the steering column, I know the trunk release relay is the one that has a small brown wire going to it and that wire is a negative trigger to pop the trunk, I also believe that the defogger relay is there but not sure which one it is...
    Hope this helps
  18. #18 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Michigan
    If you need anymore help in this area Shoot me a message, I have had 7 w-body GP's and have installed somewhere in the range of 50,000 remote start or alarms
  19. #19 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    Relay with a brown wire, got it.
    will update after I try this!
  20. #20 Re: Where is rear defogger relay wire? (and trunk relay wire)
    Pittsburg, KS
    gonna try finding brown wire, finally.
    Have you got my PM btw??
  1. TXL wire necessary?
    By Toasty in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 12:18 PM
  2. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  3. Fly by wire T/B???
    By AKGTP in forum General Tech Discussion
    Last Post: 01-30-2009, 11:36 PM
  4. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
