Thread: Turning signal relay?
Results 1 to 19 of 19
  1. #1 Re: Turning signal relay?
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    Quote Originally Posted by simbah View Post
    Your car does not have a turn signal relay. the blinking of the turn signals is controlled by the BCM, so what is happening is probably hyperflash, like you would get with LED turn signals. With that being said if you install the magic resistor, like with LEDs then your hyperflash should cease to exist.
    He is correct, the car's turn signals are controlled by the BCM. Unfortunately, the only way to fix this issue is to splice in load resistors.
    I happen to know where you can find a good deal on some
    Nick C.
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  2. #2 Re: Turning signal relay?
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by Paul J McCain View Post
    Nick C.
    I wonder where.....cause I have no ideal :beer:
  1. 06 GP Base signal conversion to Fog/signal
    By kmkecho in forum General Tech Discussion
    Last Post: 08-19-2012, 11:51 PM
  2. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. Turning Signal
    By bct717 in forum Visual/Body Modifications
    Last Post: 03-25-2009, 03:07 PM
