Thread: Cluster geat selction lights not working after trans install
Results 1 to 4 of 4
  1. #1 Cluster geat selction lights not working after trans install
    Jan 2012
    N/A
    Just got my new transmission installed and for some reason the gear selection lights for D123 do not work on the dash . P and N both light up
  2. #2 Re: Cluster geat selction lights not working after trans install
    Jan 2012
    N/A
    My bad P R N all light up. Rest don't .
  3. #3 Re: Cluster geat selction lights not working after trans install
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by DrSnazzy View Post
    Depending on what year car you have, there may be something wrong with the PRNDL switch or the wiring. It stands to reason since they'd have to disconnect it to R&R the transmission.
  4. #4 Re: Cluster geat selction lights not working after trans install
    Jan 2012
    N/A
    I did the r&r , so what should I check
  1. Gauge Cluster Not Working
    By DreadMcLaren in forum 04+ Specifics
    Last Post: 04-13-2015, 11:13 AM
  2. shift indicator light in cluster not working after gtp trans swap
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2012, 02:43 PM
  3. Cluster Stopped working.
    By Carlos773 in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2012, 08:25 PM
  4. speedo cluster not working...
    By Ballin00gtp in forum General Tech Discussion
    Last Post: 02-10-2011, 08:04 AM
  5. HVAC Cluster Back Lights / CB Radio Install
    By POLECAT2007 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 09:47 AM
