Thread: LED strips in footwells
Results 1 to 17 of 17
  1. #1 LED strips in footwells
    SE Level Member rhenuset's Avatar
    winnipeg
    I have some LED strips in my footwells hooked up to a switch so I have to turn on/off manually. I want to hook it up somewhere to have it turn on automatically with all the DIC, speedo, console and whatnot else lights. Where I could tap into? I was thinking going into the light level knob to the left of the steering wheel but I'm not to sure how much that would accomplish.
  2. #2 Re: LED strips in footwells
    Banned
    Jan 2013
    Colorado
    I would suggest the parking lights.
  3. #3 Re: LED strips in footwells
    winnipeg
    Completely forgot about that. Thanks ill check out some diagrams
  4. #4 Re: LED strips in footwells
    I live here. DirtDog's Avatar
    Jun 2012
    I wouldn't do park I wouldn't do parking lights. I just tapped into the same lights as the stock interior lighting when I changed all mine to LEDs a long time ago. Just get under the dash and cut and splice the wires together
  5. #5 Re: LED strips in footwells
    LED's will need to be dimming if you want to put them on the dimming circuit, that you mention. You sure you want them on while you are driving around?
  6. #6 Re: LED strips in footwells
    Jun 2012
    Mine aren't dimming LEDs so their on and then they just shut off. Its fine with me though. Actually didn't know they made dimming leds
  7. #7 Re: LED strips in footwells
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I hooked mine up to the fuse box with a fuse tap. I have it tapped into a power source that allows for power in both the ACC and ON positions with the key. That way I can have a dim glow while I am drving or have a dim light while the car is sitting. I figured that I would get tired of having them on all the time so I hooked up two switches. One for the front seat LEDs and one for the rears. I really like how mine are set up.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  8. #8 Re: LED strips in footwells
    GT Level Member Shiftingshaddow's Avatar
    KC
    Quote Originally Posted by burgundybullet View Post
    could you explain this a bit more to me? like what power source?
    my car had some when i got it but they didn't work. one day they randomly came on and it was because of bad ground. so i got them grounded and found out they don't shut off--at all. i thought maybe there was a remote, like for an amp, but could not find any such wire. So i put a switch in. i kind of like the switch idea but i don't know where i actually want the switch.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  9. #9 Re: LED strips in footwells
    Quote Originally Posted by Shiftingshaddow View Post
    It was in the fuse panel in the glovebox. I put a fuse tap into a spot with a 10a fuse and then put another 10a fuse into the fuse tap. I then ran one wire from that up to where I was going to put the switches where I split it to run power to both switches. Then I ran 2 wires out of one switch for the front floor LED strips. Then I ran 2 wires out of the other switch for the rear floor lights. Thats pretty much it. I could post some pictures of some of the stuff that I can get to easy enough to show you.
    Even if you want them all on one or all on all the time I would suggest re-thinking that. At first I was just going to have them all on one switch but decided to add in a seperate one for the back. So glad I did. I dont like having the light on back there if no one is sitting back there because in my mind it is a waste. I also like having the front ones shut off during the day to extend the life of the LEDs. Plus they arent really visible during the day.
  10. #10 Re: LED strips in footwells
    Sep 2011
    Arkansas
    I've simply run tapped the switched power wire in the stereo harness for a few friends who wanted footwell leds that just went on and off without a rocker switch. Never had an issue reported.
    Sent from my A200 using Tapatalk HD
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  11. #11 Re: LED strips in footwells
    Jan 2013
    Kansas
    I could use some help with this too. I bought some LED stripes a while ago and I put them down there in the foot wells and they look like. What I did is I bought a switch that you plug into one of those things (cant think of the word right now) where you can plug in like a phone car charger. and use that to turn my lights on and off. Its not that big of a hassle but if your like me you can usually forget to turn them off and cause your battery to drain. So I was wondering if anybody had any ideas where to wire them into. and how cause im not a geek on wiring. lol I can post pictures of you guys wanna see what I mean.
  12. #12 Re: LED strips in footwells
    Feb 2010
    TN
    I tapped into the light in the console for the shifter light, comes on and dims with dash-lights (Supposedly mine are non dimming too but they they a slight bit) shuts off when I shut off car or turn dash lights off
  13. #13 Re: LED strips in footwells
    Jan 2013
    Kansas
    Quote Originally Posted by Logan541 View Post
    ^ Best option, fair easy I did it myself just yesterday, I only got confused cause there where two black wires coming from the connector, but I picked one and used it for ground and they work fine! somehow I busted the bulb taking it apart so I replaced it with a LED bulb right away, my LED Strips aren't dimming ones either but they dim if I dim the interior light.... even better
  14. #14 Re: LED strips in footwells
    winnipeg
    It doesnt matter to me if the lights are on all the time when the car is on I just dont want them on when the car is off. I like the lights being on at night cus it looks sweet (and i get lots of complements). Ive taken apart the console before so tapping into the shifter light will be easy enough
  15. #15 Re: LED strips in footwells
    KC
    thanks burgandybullet. i like your car, btw. i think i'll just stick with the switch i have now. i only have them in the front--laying on the floor and my switch is hanging in the change tray through the console. i'm not sure where i want them yet.
  16. #16 Re: LED strips in footwells
    Thanks. Here are the pics that show what Im talking about incase anyone cares.
    The fuse tap on the right is in the MALL PGM spot and that is running power for the floor LEDs. It allows the LEDs to be on in both ACC and ON positions but will turn off the power when the car is turned off. That way there is no worrying about them being left on and you can have them off during the day and switch them on at night.
    These are the switches I put in. The one on the left is for the front floor LEDs and the right one is for the rear floor LEDs. I like the switches because at night if someone is complaining about them being on you can just shut them off. Plus you dont have to have the rear ones on when no one is sitting back there.
  17. #17 Re: LED strips in footwells
    Jan 2013
    Kansas
    One question.... those people that have hooked up the LED's to the gear shifter... did you guys blow the head light relay? I noticed the day after i spliced into the gear shifter that my low beams wherent working. turns out it was the HDM Module.. $43 for the relay anybody else noticed this?
  1. where to get l.e.d. strips.
    By Tha Ghost in forum Visual/Body Modifications
    Last Post: 02-24-2011, 04:16 PM
  2. LED Brake light strips
    By Lofty in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 10:22 PM
  3. Led strips
    By MidnightBlue in forum Visual/Body Modifications
    Last Post: 06-18-2010, 08:36 AM
