Thread: LED strips in footwells
Results 1 to 17 of 17
  1. #1 Re: LED strips in footwells
    GT Level Member Shiftingshaddow's Avatar
    KC
    Quote Originally Posted by burgundybullet View Post
    I hooked mine up to the fuse box with a fuse tap. I have it tapped into a power source that allows for power in both the ACC and ON positions with the key. That way I can have a dim glow while I am drving or have a dim light while the car is sitting. I figured that I would get tired of having them on all the time so I hooked up two switches. One for the front seat LEDs and one for the rears. I really like how mine are set up.
    could you explain this a bit more to me? like what power source?
    my car had some when i got it but they didn't work. one day they randomly came on and it was because of bad ground. so i got them grounded and found out they don't shut off--at all. i thought maybe there was a remote, like for an amp, but could not find any such wire. So i put a switch in. i kind of like the switch idea but i don't know where i actually want the switch.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #2 Re: LED strips in footwells
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Quote Originally Posted by Shiftingshaddow View Post
    It was in the fuse panel in the glovebox. I put a fuse tap into a spot with a 10a fuse and then put another 10a fuse into the fuse tap. I then ran one wire from that up to where I was going to put the switches where I split it to run power to both switches. Then I ran 2 wires out of one switch for the front floor LED strips. Then I ran 2 wires out of the other switch for the rear floor lights. Thats pretty much it. I could post some pictures of some of the stuff that I can get to easy enough to show you.
    Even if you want them all on one or all on all the time I would suggest re-thinking that. At first I was just going to have them all on one switch but decided to add in a seperate one for the back. So glad I did. I dont like having the light on back there if no one is sitting back there because in my mind it is a waste. I also like having the front ones shut off during the day to extend the life of the LEDs. Plus they arent really visible during the day.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. where to get l.e.d. strips.
    By Tha Ghost in forum Visual/Body Modifications
    Last Post: 02-24-2011, 04:16 PM
  2. LED Brake light strips
    By Lofty in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 10:22 PM
  3. Led strips
    By MidnightBlue in forum Visual/Body Modifications
    Last Post: 06-18-2010, 08:36 AM
