It was in the fuse panel in the glovebox. I put a fuse tap into a spot with a 10a fuse and then put another 10a fuse into the fuse tap. I then ran one wire from that up to where I was going to put the switches where I split it to run power to both switches. Then I ran 2 wires out of one switch for the front floor LED strips. Then I ran 2 wires out of the other switch for the rear floor lights. Thats pretty much it. I could post some pictures of some of the stuff that I can get to easy enough to show you.
Even if you want them all on one or all on all the time I would suggest re-thinking that. At first I was just going to have them all on one switch but decided to add in a seperate one for the back. So glad I did. I dont like having the light on back there if no one is sitting back there because in my mind it is a waste. I also like having the front ones shut off during the day to extend the life of the LEDs. Plus they arent really visible during the day.
