Decided to save some $$ and probably go with a single 15" setup.
Amazon.com: Alpine Type-R SWR-1542D - Car subwoofer driver - 750 Watt - 15": Car Electronics
Will this amp power it well?
Amazon.com: Hifonics Brutus BRZ1200.1D D-Class Mono Block 1 x 450 @ 4 OHMS, 1 x 900 @ 2 OHMS, 1 x 1200 @ 1 OHM: Car Electronics
I'd be doing a 4ohm DVC sub wiring it to a 2ohm load. On this amp a 2ohm load is 900rms, the sub rms is like 800. Right?
your right, should be well within reason. if you can get a non clipped clean signal you could push more to it. but for what you want it should sound just fine.
I'll probably get a box locally, a 15 fits in the grand prix right? lol. Definitely going ported. Figured the Brutus is a good choice on an amp.
yeah the brutus will get the job done, and a 15 should fit, a correct box will still be big though. but it will fit!
I'm an idiot..the p3 that I thought i blew a voicecoil in..I tried hooking up to my amp that wasnt 2ohm stable on a bridge. the highest rms is 1x400 on a 4ohm load. So I just threw away a p3 last week that was probably working. FML
was the amp going into protect? only way to tell is volt meter, or stick a 9 volt to the terminals and "pop" it. Box should fit just fine dont worry. just measure it before it goes in
I dont think it was going into protection mode. Maybe one of the voice coils did blow but I looked at the specs of my amp i have now and it makes sense. yeah im gonna test it out before i buy it, prob going to Audio Tech again off 159. I've never had issues with his boxes. I have a feeling it'll be $70
Local shop around here. The guy sells a bunch of offbrand electronics, as well as a lot of boxes. I don't see it costing me too much. Probably $69, at most $89.
Op look into a crescendo amp.. Waaaaaayyy better than the hifonics shiit! Would also go a different route on that 15 too... How much u trying to save up..??
Man, thats a big a$$ woofer. Too big for my taste, but then again, I barely fit my two sealed 12's. Hope it turns out killer and that it sounds just the way you want it too. I guess im worried that a ported 15 might give you too much "boom" and rattle the $hit out of everything. Sure as heck will know its there though haha
I used to enjoy having just the 12" with the vpower 500 amp, this time I'm almost doubling the wattage and having 3" bigger of a sub in a larger trunk. should go well with the monsoon sound system. Figured a white pontiac with 18" wheels and tinted windows needed a large boom haha
L M F A O!!!! Are serious bout that..?!? Your goal is to hear it out side the car??!!
Just make sure you get a box built around your cars cabin gain... Will a sound good and if the whole system is tuned correctly you will be able to hear outside the car and some! :-)
| « Previous Thread | Next Thread » |
| Tags for this Thread |
