Thread: Problem progamming 99 Key Fob
Results 1 to 3 of 3
  1. #1 Problem progamming 99 Key Fob
    Oct 2012
    Canada
    So my key fob up and died the other day out of no where. Took it apart, tested the battery, had tons of power still but i replaced it anyways and yet the key fob still doesn't work.
    Tried cleaning the key fob and all the connections... still nothing. So i figured maybe i gotta re program it to the car. Tried holding the lock + unlock buttons for 7 seconds near the car, no horn sound at all (maybe cause i have the DRL fuse pulled? only reason i say that is because when i would lock the car before with no DRL fuse i wouldn't get a horn beep after locking it, so maybe the DRL fuse has to be in?)
    Anyways that didn't work so i figured id try pregoramming the key fob to the car by following the steps found on the board. Pulled Mall PGM fuse, turn key to acc, then off, then back to acc within 1 second, open drivers door and close and then this is when i hear a series of beeps. Car beeps once, then twice, then once, then twice, then once, and twice again, then no more beeps. So i then hold the lock + unlock on the key fob for 14 seconds and i hear no beeps at all and key fob still doesn't work.
    Whats going on here? what am i doing wrong?
  2. #2 Re: Problem progamming 99 Key Fob
    Houston
    Sounds like a bad fob.
  3. #3 Re: Problem progamming 99 Key Fob
    Oct 2012
    Canada
    That's what im starting to think as well. Maybe il get my co-worker to take a look at it and see if he can fix it since he has all the tools to do that kinda stuff.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Problem
    By Iceman6669 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2011, 04:44 PM
  4. A/C problem
    By GTP2188 in forum General Tech Discussion
    Last Post: 07-25-2011, 01:29 PM
  5. Yet another a/c problem
    By disblile in forum General Tech Discussion
    Last Post: 07-18-2011, 05:31 PM
