Would I have to run additional speaker wire from the head unit?
Is speaker wire safe to run along the power cable?
Safe yes. Recommended no. You can get electrical interference ie that whining buzzin sound.
But how would I run the front door speaker wire to the back if the power wire is on that side?
Run power wire down the center of the car.. FIXED! See if it has noise. If it doesn't don't worry about it. RCA's seem to be more effected by running them near the power wire than speaker wire in my experience.
How would I do the in my gtp coupe?
What?!?!
I have my power wire down the side of my car, including my front speaker wire too, no noise interference after a year so far, but i do also have something called a "ground loop isolator" to remove any electrical interference noise that i had, (but that was from a bad ground i made).
4 CHANNEL RCA GROUND LOOP ISOLATOR REMOVE NOISE FILTER REDUCER AMP INSTALL | eBay
First of all, fix the ground and remove the ground loop isolator. That's honestly a bandaid for something that really should be there in the first place. Also, you can run speaker wires next to your power wires, since the signal is already amplified, any interference would be unnoticeable. That being said, don't ever run your rcas next to your power wire, it is an I amplified signal and anything it picks up will only get louder.
Where should I mount my amp?
Yeah man for sure. Just wanted to make sure you got the best from your system. You should mount your amp in the trunk silly goose.
LolI mean specifically where
Umm, I've heard good things about people mounting them to the back of the rear seats or the pass through if your amp is small enough.
This prolly sounds dumb, but how do I mount it?
Are JBL GTO series good speakers?
