Thread: new speakers
Results 1 to 19 of 19
keenan00gtp new speakers 12-02-2008, 04:55 PM
GeddyLee Re: new speakers 12-02-2008, 05:55 PM
gtpinsc Re: new speakers 12-03-2008, 08:11 PM
keenan00gtp Re: new speakers 12-07-2008, 02:00 PM
gtpinsc Re: new speakers 12-07-2008, 03:06 PM
Jeff Re: new speakers 12-21-2008, 05:15 PM
reinke Re: new speakers 12-08-2008, 12:19 PM
99prixgt Re: new speakers 12-08-2008, 02:48 PM
reinke Re: new speakers 12-08-2008, 08:46 PM
keenan00gtp Re: new speakers 12-09-2008, 09:40 AM
reinke Re: new speakers 12-09-2008, 05:28 PM
keenan00gtp Re: new speakers 12-09-2008, 09:29 PM
reinke Re: new speakers 12-09-2008, 10:16 PM
keenan00gtp Re: new speakers 12-10-2008, 03:58 PM
reinke Re: new speakers 12-10-2008, 11:03 PM
99prixgt Re: new speakers 12-12-2008, 12:07 AM
gtpinsc Re: new speakers 12-22-2008, 09:31 PM
reinke Re: new speakers 12-23-2008, 01:10 AM
Jeff Re: new speakers 12-24-2008, 04:52 PM
  1. #1 new speakers
    SE Level Member keenan00gtp's Avatar
    Oct 2008
    Iowa
    so i bought new speakers for my gtp (2 door) how do you get the doors and rear deck off?
    so far: borla catback exhaust, audio swap.
    waiting for warmer temps
  2. #2 Re: new speakers
    St. Louis Mo.
    Well its not hard, just time consuming really. There are two screws underneather the door handle that you need to take out before removing the actual door skin. They Torx style heads, so you need torx bits to remove them, cant remember the exact size of them, but they are of the larger variety. Once you have those two removed, you can pop out your Windows and Door lock panels and leave them lose for the moment. Once you have done that, you will either an upholstry tool to slip behind the door skin to start the removal process or some really strong fingers to get the plastic clips to release.
    Once you have worked your way around the door, you can slide the control units out of the door skin and you should have a nicely exposed inside to your doors. I am not 100% on this, but if you have the Bose Speaker setup, there will be black panels securing in the 5" speakers on the doors. You can reuse that mount for your new speakers. Even if they are of the 6.5" variety. I did this with mine. I just dremelled part of the plastic out of the way and was able to get them to fit perfectly.
    As for the rear deck speakers............This is where the fun begins.
    You have two tabs on both sides of the bottom seat cushion in the rear. You need to pull those till the tabs pop and the bottom seat cushion releases. Once it has released you can remove it and place it off to the side. After that you will see at least 3 large bolts holding in the upper rear part of the seat, and two (one for each) bolts holding down the seat belt buckles. You will need to remove them and place them out of the way. Once you have done that, you just simply lift up on the seat backing where its secured by three hook like objects. Once you lift high enough, you will unhook from those. Them move the back seat to location outside the car. REMEMBER that back portion of the seat is rather heavy with lots of sharp edges so be mindful of your paint.
    Ok now we are on the downhill side of things. Once you have removed the lower and upper seat cushions, you will see the decklid. You simply slip the seat belts out from the corners and gently lift up the decklid. Once high enough to go over the speakers you pull it towards yourself gently. Once removed place it outside the car as well. There will be a layer of carpet foam stuff and a layer of rubber vinyl like material beneath. The top layer of the carpet foam stuff comes off. The rubberized material is attached to the seat, so you just pull that down and out of the way.
    Then you will have access to your rear decklid speakers.
    I hope that helps explain it? If you need more assistance, please let me know. I will try and help if I can.
    James Shafer
    St. Louis MO
  3. #3 Re: new speakers
    Jul 2008
    sumter,south carolina
    i just did all that a few months ago,i think u broke it down pretty good.
    02 GTP with mods 05 GP for DD
  4. #4 Re: new speakers
    Oct 2008
    Iowa
    ok so i got the speakers out and everthing. i am a complete noob when it comes to all this. the new speakers i got dont use the factory connector. so im guessing i will have to cut it off. but the next problem is idk which wire goes where. on the passenger side the 2 wires are green and blue. on the drivers side they are yellow and black. what goes where? help!
  5. #5 Re: new speakers
    Jul 2008
    im assuming this info is right,the guy that posted knows a good bit about stereos and wiring...and from what i can remember thats how my colors matched up...
    http://www.grandprixforums.net/f41/s...wire-8449.html
  6. #6 Re: new speakers
    Dec 2008
    INDIANA
    Trying to find the right after market stereo for my 98 GT. One that has the right color display and goes good with everything. Ant suggestions. Thanks
  7. #7 Re: new speakers
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    correct i used the directtech program from DEI to ge those. it is the best thing to use besides a factory wiring diagram.
  8. #8 Re: new speakers
    Jersey
    speaker plug adapters make the job go a whole lot faster
    16' wrx sti- stock
  9. #9 Re: new speakers
    Oct 2008
    cleveland, ohio
    Quote Originally Posted by 99prixgt View Post
    but why buy them. they are not needed at all.
  10. #10 Re: new speakers
    Oct 2008
    Iowa
    Quote Originally Posted by reinke View Post
    what are they? can i just hook the car wires straight to the speakers?
  11. #11 Re: new speakers
    Oct 2008
    cleveland, ohio
    yes you can. the plugs he is talking about clip into the factory speaker harness in the door and have 2 wires on the other end. pretty much there usually $10-$20 and are not needed.
  12. #12 Re: new speakers
    Oct 2008
    Iowa
    ok what do think i should hook the wires that came with the speakers to the factort harness then to the speakers because they have the little clips or can i just go straight from the factory harness to the speaker?
  13. #13 Re: new speakers
    Oct 2008
    cleveland, ohio
    i always use the wires that come with the speakers. but it is completely up to you.
  14. #14 Re: new speakers
    Oct 2008
    Iowa
    does it matter at all?
  15. #15 Re: new speakers
    Oct 2008
    cleveland, ohio
    does not matter one bit.
  16. #16 Re: new speakers
    Jersey
    i got my speaker plug adapters for about $5
    16' wrx sti- stock
  17. #17 Re: new speakers
    Jul 2008
    I always suggest Pioneer Premier,but thats just me.Theres alotta good decks out.I suggest going to ur local car stero shop so u can have hands on and see what options they have and so forth.
  18. #18 Re: new speakers
    Oct 2008
    cleveland, ohio
    wow jeff talk about a thread jack.
  19. #19 Re: new speakers
    Dec 2008
    INDIANA
    Hows this GO **** YOURSELF
  1. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
  2. Speakers & Ipod
    By kahluatoo in forum General Tech Discussion
    Last Post: 06-02-2008, 11:56 PM
  3. no rear speakers
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 06:44 PM
  4. Any way to make 6 1/2 speakers fit?
    By Deezul_AwT in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2008, 11:03 PM
