Thread: Amping speakers?
Results 21 to 40 of 63
  1. #1 Re: Amping speakers?
    Jun 2012
    United States
    hes only got one amp
  2. #2 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Wtf is a distribution block?
  3. #3 Re: Amping speakers?
    Jun 2012
    United States
    It is like the same concept is a cable spliter, so you can run multiple tv's of of one cable coming into the area
  4. #4 Re: Amping speakers?
    Jun 2012
    United States
    it allows you to run multiple amps. For instance you would run your main 0 gauge from the car battery to the distribution block which is in the trunk, and you could run two, three or more power wires off of that so you can run multiple amps off of the main power wire. You got make sure that your main power wire is rated for the power your gonna have for all the amps combined tho, meaning dont run no 8 gauge crap to a distribution block then run multiple amps off of 8 gauge. The bigger the better is ideal for that main power coming from the battery, i always go 0 gauge
  5. #5 Re: Amping speakers?
    Jun 2011
    Detroit, MI
    You are making it too complicated.
    First, get a nice head unit to your liking, and finish installing it. Here is the one I got: Kenwood Excelon KDC-X896 CD receiver at Crutchfield.com
    NEXT:
    Buy one 4-channel amplifier, power the front speakers with channels 1 & 2. Bridge channels 3 & 4, to power your subwoofer.
    You will need 2 pairs of RCA cables to connect from the "front" channel of the headunit to the amp, and the "sub" channel of the HU to the amp.
    To power the amplifier, you will need at least a 4 gauge amplifier wiring kit, so get that all wired up, connect your speakers and you are ready to go!
    Yes it can be pretty complicated, but it is worth it!
    Here is the 4-channel amplifier I have (I chose it because of the high output especially at 4 ohms bridged, and for the fact that it is CEA-2006 compliant): Hifonics ZRX1000.4 1000W RMS, 4-Ch Class A/B Zeus Series Car Amp
    PS you don't need to amplify the rear speakers at this point. Just replace the speakers for now and amp the fronts and sub.
    iLoveSpade
  6. #6 Re: Amping speakers?
    Jun 2012
    United States
    Not at all. You would never finish installing a headunit then tear it back out to run rca's to it. Do it all at the same time if your planning on running an amp.
  7. #7 Re: Amping speakers?
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Bheat55 View Post
    I know, I was just trying to break it down for him. When I put my new HU in, I ran the two pairs of RCA's through to the trunk so they were ready when I was ready to get my amp. (Of course the ones I used were really ****ty and I need to tear it out and put better ones in. Question: Would really ****ty RCA's cause a slight delay for my sub?)
    iLoveSpade
  8. #8 Re: Amping speakers?
    Jun 2012
    United States
    I figured that what you ment, i just didn't want him installing the cd player thinking it's easy to come back and hook up the rca's. You def. want to do it all at the same time if you can
  9. #9 Re: Amping speakers?
    Jun 2012
    United States
    Ya you will prolly blow the 4" speakers cause the 6x9's can handle a hell of alot more the 4" speakers, or it will greatly underpowered cause your gonne have to not run as much power to them, and then your not getting the full potential out of your speakers.
  10. #10 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    I plan on amping all six speakers to my 4 channel amp. The rear 6x9's have 4" speakers next to them, so is there a way to connect those two to one channel? My speakers will have enough bass to where I wouldn't need a sub.
  11. #11 Re: Amping speakers?
    Jun 2011
    Detroit, MI
    Quote Originally Posted by mick777wauchope View Post
    Hmm, I honestly wouldn't bother amping the 4" speakers because there is gonna be quite a power handling difference between the 6x9's and the 4" ones. Switch out all the speakers, power your 5.25's and your 6x9's, and leave the 4" ones on stock wiring, unless they don't work on stock wiring. I guess you could power both on one channel, but I'm not sure what the overall impedance would be on your amp, so getting the right amount of power to your 6x9's will be tough. (You can try it though).
    iLoveSpade
  12. #12 Re: Amping speakers?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by Hippo Machine View Post
    I second this. It is the best plan if you want to run power to all 6 speakers. Just use the stock power coming from your new HU. Should be enough to pump those little speakers, although I would look into a set of bass-blockers so your not feeding the lows into those little guys using like 15w RMS from your HU, that would be bad news.
    Infinity all around.
  13. #13 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Quote Originally Posted by chamilton89 View Post
    I'm not sure I could run them from my head unit, because I am bypassing the Bose amp and wiring...
  14. #14 Re: Amping speakers?
    GTP Level Member simbah's Avatar
    Lala land
    If you are replacing the 6x9 with new aftermarket speakers then I wouldn't even bother hooking up the 4" speakers again. The new 6x9 will probably drown them out anyway.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  15. #15 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    So I should just return my new 4-inches?
  16. #16 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Or would connecting them to my front 6.5" speakers would be better?
  17. #17 Re: Amping speakers?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    It depends on the rms rating of the speakers. I have my 4" and 6x9" both rated to 35w rms wired in series and powered by a 75w rms amp.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  18. #18 Re: Amping speakers?
    GTP Level Member
    springfield IL
    This is going to be a disaster I can see it already!!!!
  19. #19 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Why..
  20. #20 Re: Amping speakers?
    Long Island , NY
    it doe-sent take much time or effort to gain access to the head unit....seams like its easier to install that make shure it works as it should trouble shoot it if need be then go back and wire in all the speakers and amp at once wile the interior is apart. just my 2 cents
  1. new speakers
    By Pkorn in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 05:54 PM
  2. speakers
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-08-2009, 01:26 PM
  3. new speakers
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2008, 04:52 PM
