Thread: Amping speakers?
Results 41 to 60 of 63
  1. #41 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Quote Originally Posted by chamilton89 View Post
    I second this. It is the best plan if you want to run power to all 6 speakers. Just use the stock power coming from your new HU. Should be enough to pump those little speakers, although I would look into a set of bass-blockers so your not feeding the lows into those little guys using like 15w RMS from your HU, that would be bad news.
    I'm not sure I could run them from my head unit, because I am bypassing the Bose amp and wiring...
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by mick777wauchope View Post
    Sure you can. Your headunit includes amplified outs to run speakers if you didn't have an amplifier, just use the rear two channels to power your 4 inchers.
    Infinity all around.
  3. #43 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Would I have to run additional speaker wire from the head unit?
    I'm not sure how the original Bose system was wired but doubtful. And if you did, jut run it when you run your rcas.
  5. #45 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Is speaker wire safe to run along the power cable?
  6. #46 Re: Amping speakers?
    Topeka, KS
    Safe yes. Recommended no. You can get electrical interference ie that whining buzzin sound.
  7. #47 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    But how would I run the front door speaker wire to the back if the power wire is on that side?
  8. #48 Re: Amping speakers?
    Topeka, KS
    Run power wire down the center of the car.. FIXED! See if it has noise. If it doesn't don't worry about it. RCA's seem to be more effected by running them near the power wire than speaker wire in my experience.
  9. #49 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    How would I do the in my gtp coupe?
  10. #50 Re: Amping speakers?
    Topeka, KS
    What?!?!
  11. #51 Re: Amping speakers?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I have my power wire down the side of my car, including my front speaker wire too, no noise interference after a year so far, but i do also have something called a "ground loop isolator" to remove any electrical interference noise that i had, (but that was from a bad ground i made).
    4 CHANNEL RCA GROUND LOOP ISOLATOR REMOVE NOISE FILTER REDUCER AMP INSTALL | eBay
    First of all, fix the ground and remove the ground loop isolator. That's honestly a bandaid for something that really should be there in the first place. Also, you can run speaker wires next to your power wires, since the signal is already amplified, any interference would be unnoticeable. That being said, don't ever run your rcas next to your power wire, it is an I amplified signal and anything it picks up will only get louder.
  13. #53 Re: Amping speakers?
    Jun 2011
    Relax brah, everything works fine. Once i reinstall my subs then ill fix it, in the mean time, its no big deal to me..
  14. #54 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Where should I mount my amp?
    Yeah man for sure. Just wanted to make sure you got the best from your system. You should mount your amp in the trunk silly goose.
  16. #56 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Lol I mean specifically where
    Umm, I've heard good things about people mounting them to the back of the rear seats or the pass through if your amp is small enough.
  18. #58 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    This prolly sounds dumb, but how do I mount it?
    There should include a set of supplied screws to mount your amplifier. These screws could be too long for lounging to the rear of the seat and you may need shorter ones.
  20. #60 Re: Amping speakers?
    Apr 2012
    Wyoming, MI
    Are JBL GTO series good speakers?
  1. new speakers
    By Pkorn in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 05:54 PM
  2. speakers
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-08-2009, 01:26 PM
  3. new speakers
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2008, 04:52 PM
