Thread: help installing new head unit (with video)updated
Results 1 to 20 of 25
  1. #1 Re: help installing new head unit
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Quote Originally Posted by chamilton89 View Post
    My pioneer head unit is wired just as yours is, and you can still do the grounding with your RCS's. Inside of your head unit, all of the grounds are wiring together, so if you have ground one, you have grounded them all. So, this still leaves you with the issue of running a wire to the dongle with all of your RCA outs. Just ground your RCA's on the other end of the wire, against your amplifier. Smoosh a small gauge wire in-between the ground on the RCA and receptacle for your amplifier. Like I said before, just ground one of them and your entire system is grounded. Hope this helps.
    this seems a bit confusing to me. My amp is in the trunk where as all the rcas are in the front at the deck can you please specify what to do? Thanks
  2. #2 Re: help installing new head unit
    Houston
    Quote Originally Posted by des19 View Post
    Your problem is coming from the non amplified speakers. You wont need to do this. As others said, check your HU's ground. If it didnt happen with the stock unit, then your issue is either a noisy HU or you have a weak connection at your ground wire on the HU. A real quick test, just run your own ground wire, connect it and see if the alt noise goes away. If it doesnt, plug your stock HU back in and if it's gone, your new HU has problems.
    Quote Originally Posted by logan809 View Post
    Probably a last resort but are your spark plug wires in good shape? I've read some cheaper brands can cause alot of radio interference and static..
    If that were the case, you'd run into the same issue with the stock unit.
  1. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  2. took out old head unit put in new one
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2009, 12:39 PM
  3. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
