You might need a ground loop isolator for your rca's or inputs. You can also ground the radio with a separate ground vs using the stock harness ground or use both.
I have looked into this stuff. Im thinking I need a different noise filter not the one that goes through the amp because I am only getting bad static from the speakers. The only thing I have hooked up to my aftermarket amp is my 2 subs.
