Thread: help installing new head unit (with video)updated
Results 1 to 20 of 25
des19 help installing new head unit... 02-29-2012, 08:03 PM
rynoman03 Re: help installing new head... 02-29-2012, 08:30 PM
des19 Re: help installing new head... 02-29-2012, 08:34 PM
des19 Re: help installing new head... 03-01-2012, 12:19 AM
rynoman03 Re: help installing new head... 03-01-2012, 01:42 AM
des19 Re: help installing new head... 03-01-2012, 01:55 AM
rynoman03 Re: help installing new head... 03-01-2012, 02:59 AM
des19 Re: help installing new head... 03-01-2012, 01:48 PM
chamilton89 Re: help installing new head... 03-01-2012, 02:34 PM
SlowNA06 Re: help installing new head... 03-01-2012, 02:39 PM
des19 Re: help installing new head... 03-01-2012, 06:39 PM
chamilton89 Re: help installing new head... 03-01-2012, 10:18 PM
des19 Re: help installing new head... 03-02-2012, 01:03 AM
KeithGTP03 Re: help installing new head... 03-02-2012, 01:44 AM
logan809 Probably a last resort but... 03-01-2012, 10:58 PM
logan809 Guess that's true 03-02-2012, 09:36 AM
des19 Re: help installing new head... 03-03-2012, 06:39 PM
KeithGTP03 Re: help installing new head... 03-04-2012, 12:08 AM
des19 Re: help installing new head... 03-04-2012, 01:37 AM
des19 Re: help installing new head... 03-05-2012, 06:47 PM
KeithGTP03 Re: help installing new head... 03-05-2012, 11:00 PM
des19 Re: help installing new head... 03-05-2012, 11:10 PM
rynoman03 Re: help installing new head... 03-06-2012, 04:05 AM
I800C0LLECT Re: help installing new head... 03-06-2012, 12:25 PM
des19 Re: help installing new head... 07-26-2012, 03:25 PM
  1. #1 help installing new head unit (with video)updated
    GT Level Member des19's Avatar
    May 2011
    Ontario
    hey guys, I recently installed a pioneer head unit in my gp. However I am getting really bad static out of all the speakers now. The system runs good with loud bass but when you turn down the volume you can really hear the static. Any ideas? The static stays the same volume and is on with the radio or the ipod hooked up?!
    Also regarding another issue..I am trying to install a pak module to retain wheel controls. I have the adapter for the chimes but now when I go to install the pac module, can the green wire that I need to connect to pin A7 go right at the stock radio harness? Also it says to connect pin A6 to a switched 12v source so does this mean I cut the wire from pin A6??
    Pleae help..audio on these cars is horrible to work with!
    UPDATE: video radio buzzing after pioneer head unit install - YouTube
  2. #2 Re: help installing new head unit
    Topeka, KS
    How well is your radio grounded? It sounds like your picking up electrical noise. Usually ground related. Also make sure you car's grounds are tight and free of corrosion. Check out the "Big 3" upgrade.
    As for the wires that need to go to a switched 12v just tap into a switched 12v source. Don't cut factory wires. Splice with a vampire tap / posi tap if you have to.
  3. #3 Re: help installing new head unit
    May 2011
    Ontario
    Quote Originally Posted by rynoman03 View Post
    Thanks.. Also the static was never there with stock head unit so not sure what it could be. The amp the subs go to are grounded well. Never had an issue with the amp. Just as soon as I install an aftermarket HU, I get a ton of static.
  4. #4 Re: help installing new head unit
    May 2011
    Ontario
    update...buzzing sounds get higher pitched as I accerlerate, not louder, higher pitched? All sounds turn off once I turn off the head unit. I am also getting a little thump from the subs as I turn on the radio to use the ipod or radio..along with loud buzzes.. Any thoughts??
  5. #5 Re: help installing new head unit
    Topeka, KS
    You might need a ground loop isolator for your rca's or inputs. You can also ground the radio with a separate ground vs using the stock harness ground or use both.
    Check this out...
    PAC SNI-1 RCA Ground Loop Noise Isolator - Reviews at Crutchfield.com
    http://www.amazon.com/Stinger-SGN20-.../ref=pd_cp_e_0
    As for the ipod it probably wouldn't hurt to use one of these unless your headunit controls your ipod.
    http://www.amazon.com/Pyle-PLGI38RI-.../dp/B004HJ35RK
  6. #6 Re: help installing new head unit
    May 2011
    Ontario
    Check this out...
    Amazon.com: Stinger SGN20 Ground Loop Isolator: Car Electronics
    I have looked into this stuff. Im thinking I need a different noise filter not the one that goes through the amp because I am only getting bad static from the speakers. The only thing I have hooked up to my aftermarket amp is my 2 subs.
  7. #7 Re: help installing new head unit
    Topeka, KS
    Try running a separate ground for your radio and report back. Also take a quick look at the grounds from your bat to your frame / chassis.
  8. #8 Re: help installing new head unit
    May 2011
    Ontario
    going to try to trouble shoot on saturday..
  9. #9 Re: help installing new head unit
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I know pioneer head units have an internal fuse that is on the ground for the RCA's and a lot of times it is blown due to issues during installation. I know this is true for the RCA's but I don't know, if it was blown, and you were running on the head unit, if it would ruin the ground on the internal amplifiers input. May be worth separately grounding your RCA cables as well. Its obviously a ground issue, hence you were describing alternator whine (the higher pitch when you accelerate) tone. Gotta check your grounds! and take a look at the solution I presented.
    Infinity all around.
  10. #10 Re: help installing new head unit
    Pennsylvania
    You read this sticky, right? Because it's at the top of the forum page. It's super helpful.
    http://www.grandprixforums.net/feedb...ems-17284.html
  11. #11 Re: help installing new head unit
    May 2011
    Ontario
    Quote Originally Posted by SlowNA06 View Post
    I did read this. I cant do this suggestion because my RCAs come off of a harness from the head unit (in other words there is a little harness plugged into the deck and then all the RCAs after hence cannot ground them like that)
    will trouble shoot saturday
  12. #12 Re: help installing new head unit
    Quote Originally Posted by des19 View Post
    My pioneer head unit is wired just as yours is, and you can still do the grounding with your RCS's. Inside of your head unit, all of the grounds are wiring together, so if you have ground one, you have grounded them all. So, this still leaves you with the issue of running a wire to the dongle with all of your RCA outs. Just ground your RCA's on the other end of the wire, against your amplifier. Smoosh a small gauge wire in-between the ground on the RCA and receptacle for your amplifier. Like I said before, just ground one of them and your entire system is grounded. Hope this helps.
  13. #13 Re: help installing new head unit
    May 2011
    Ontario
    Quote Originally Posted by chamilton89 View Post
    this seems a bit confusing to me. My amp is in the trunk where as all the rcas are in the front at the deck can you please specify what to do? Thanks
  14. #14 Re: help installing new head unit
    Houston
    Your problem is coming from the non amplified speakers. You wont need to do this. As others said, check your HU's ground. If it didnt happen with the stock unit, then your issue is either a noisy HU or you have a weak connection at your ground wire on the HU. A real quick test, just run your own ground wire, connect it and see if the alt noise goes away. If it doesnt, plug your stock HU back in and if it's gone, your new HU has problems.
    Quote Originally Posted by logan809 View Post
    Probably a last resort but are your spark plug wires in good shape? I've read some cheaper brands can cause alot of radio interference and static..
    If that were the case, you'd run into the same issue with the stock unit.
    SE Level Member logan809's Avatar
    Sep 2011
    Kansas
    1997 Grand Prix GTP
    Ported Gen 3, Ported TB, FWI
    Sep 2011
    Kansas
    Guess that's true
    1997 Grand Prix GTP
  17. #17 Re: help installing new head unit
    May 2011
    Ontario
    UPDATE:
    today I tried checking all the grounds, rewired the entire head unit, tried rerouting rcas from amp in back, also disconected previous LOC that was using and nothing! Still getting a lot of buzzing and alternator whineing (goes higher pitch when you rev). Im thinking my last option is to try some kind of noise filter. Now I have 3 rca outs for the speakers would I have to filter them all? Any suggestions would be good. Have been trying to solve this problem for a week now.
    Note: (never had any problems with stock HU)
  18. #18 Re: help installing new head unit
    Houston
    Are you running an amp for your mids and highs? If not, there is no need to filter preouts that are not being used. Since you've checked the grounds, the last thing I would check is your sub amp. Remove the rca's from the amp and see if noise goes away. You may be getting a feedback usually caused by the rca's ran next to a power line. If the noise remains, return the HU.
  19. #19 Re: help installing new head unit
    May 2011
    Ontario
    I have the monsoon system so it comes with a factory amp for all the speakers, but the speakers are connected with rcas at the front with the deck.
  20. #20 Re: help installing new head unit (with video)updated
    May 2011
    Ontario
  1. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  2. took out old head unit put in new one
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2009, 12:39 PM
  3. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
