Thread: help installing new head unit (with video)updated
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #1 Re: help installing new head unit (with video)updated
    Houston
    I would get one ground loop isolator, connect it to one of your channels and disconnect the other channel and see if it goes away. If it does, just get another and be done with it.
  2. #2 Re: help installing new head unit (with video)updated
    GT Level Member des19's Avatar
    May 2011
    Ontario
    wow, ALL I had to do was reground the RCAs and bam the noises are 90% gone, however there is a VERY slight buzzing still present. Any ideas how to get FULL quiet out of the speakers when the head unit is powered? I am happy with how it is now but could always use some advice.
    Thanks to everyone who helped me solve this issue!!
  3. #3 Re: help installing new head unit (with video)updated
    Topeka, KS
    Here's another idea... I've had a stereo shop to this. They soldered a wire to the outsides of all of the rca's and then grounded them to a screw/bolt on the back of the radio. They said this helps with the alt noise.
  4. #4 Re: help installing new head unit (with video)updated
    Feb 2009
    Virginia
    http://www.amazon.com/Axxess-AIP-AV5.../dp/B003FP5C8C
    Use that and plug directly into the amplifier and see if there's any noise.
    Success?....no noise? Then move up the cable next to the head unit. Amazon.com: female to female rca coupler: Electronics
    Use the RCA coupler to plug your iPod into the RCA cable leading to the amp. Success?....no noise? Then the problem is the Head Unit. DO NOT EVER PLUG/UNPLUG A HOT RCA CABLE!!!!! Pioneers will blow an internal fuse. ONLY PLUG/UNPLUG RCA CABLES WHEN THE UNIT IS OFF!!!!!!
    11 is louder than 10!
  5. #5 Re: help installing new head unit (with video)updated
    May 2011
    Ontario
    THREAD REVIVAL!!
    UPDATE:
    After 4 months of living with the problem, I decided to see a buddy who also is familiar with car audio as I am,
    turns out the gmos-04 adapter has 2 potentiometers inside of it (one for door chime volume one for audio volume)
    after fiddling around for hours checking grounds once again checking everything we found that turning down the audio potentiometer in the gmos-04 got rid of the static + alt whine i was getting!!
    Bull s**t!
    anyways I am pleased with my system now loud as hell and while we were at it disabled the dvd parking break. (no I will not wath when driving just wanted the feature for passengers etc..)
    Now I feel I am the master when it comes to the gmos adapters for gm vehicles having spent hours on it!
  1. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  2. took out old head unit put in new one
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2009, 12:39 PM
  3. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
