Thread: picking the right amp?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 105
  1. #1 Re: picking the right amp?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Yup. That is completely right. I also think someone else mentioned that you should be on the higher side of what your subwoofers RMS rating is, rather than the lower. That and you can even go a little over if you need to without damaging them. Also, one thing is that when you actually do the wiring itself, MANY mono-amplifiers have two sets of speaker terminals. These are there for your convenience and you should most certainly feel free to take advantage of them because they wire up the speakers the same way your picture describes.
    Infinity all around.
  2. #2 Re: picking the right amp?
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    what about this amp?
    Renegade REN-850S - Custom Radio Buffalo
    from bestbuy
    Renegade - REN 850 S Car Amplifier - 225 W @ 4 Ohm - 1 Channel - REN 850 S
    now that i have an idea of what i'm looking for i just dont know about the quality
  3. #3 Re: picking the right amp?
    That amp is rated 225W at 4ohms. It didn't mention anything about running at 2 ohms so I can't say much about it's power delivery. May I make a recommendation for an amplifier I have worked with and enjoy. Its an infinity REF1300A and can be found for less than $150 online. Its a great amplifier at a great price and would work with your two subwoofers wonderfully.
  4. #4 Re: picking the right amp?
    Nov 2011
    Decatur
    I knew it was a matter of time before you suggested infinity... lol but that's okay it's a great brand! and that amp looks perfect except I find it saying it's 300w some places and like best buy (with their awful website) says 342w
  5. #5 Re: picking the right amp?
    I'm sorry. It's just a suggestion. I've had great luck with infinity but there are many other great amplifiers as well out there. After reading the manual for the ref1300a it outputs 300w rms and 342w dynamic power, or peak power. These are perfect numbers for your subs.
  6. #6 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    I've been through this before. Power matching sounds sensible, but you'll be better off getting an amp that puts out 100-200 more watts RMS, and then tuning it properly. Most people have the tendency to say "oh hey my subs and amp match power, i'll crank them all the way up, that should work." On the other hand, not all units produce what they say they do. If you get a multi-meter and tune it, you can get a pretty accurate idea of what you're putting out and safely give the subs the power they need.
    I'm running 4 kicker comps that take 150rms each as well, on a single 1000w RMS monoblock d class amp. 150x4 = 600, i have 400 watts there that are not being used, BUT i have my setup tuned properly. Before that I had 2 of those subs and a 300w RMS amp and the amp just **** on me.
  7. #7 Re: picking the right amp?
    Nov 2011
    Decatur
    thanks for the input everyone but the more wattage usually means the more money too! i really think the amp that chamilton posted is like perfect! i just need to see how much my buddy can get for it! and chamilton no need to appologize i was only kidding you! im going to look further into that amp and hopefully get it! sean if you have another suggestion for an amp thatd be welcomed too! thanks again!
    next step! finding a double din headunit! lol
  8. #8 Re: picking the right amp?
    Topeka, KS
    I would honestly get a little bit more amp than you need. If you have to turn your amp past 3/4 gain you need a bigger amp. It's always best to have more power than need vs not enough.
  9. #9 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    Agreed. I got my D Class monoblock for 120. Never gets hot. Ever. 1000w rms. That's awesome imo.
  10. #10 Re: picking the right amp?
    ^^^^ 4 kicker comps? or 4 kicker components? if its 4 subs i demand pics now!!
  11. #11 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Comps, as in 12 inch subs. I'm working on a fresh box. I'll have pics in maybe a week or so.
  12. #12 Re: picking the right amp?
    Nov 2011
    Decatur
    grrr. just when I thought I had the perfect amp!! so what would you guys suggest? 500w amp? any specific amps would be awesome!
  13. #13 Re: picking the right amp?
    Topeka, KS
    300watts RMS means that's a constant power you need. Peak does not = Constant.
    This would be a decent one.
    http://www.sonicelectronix.com/item_...-HFi1500D.html
  14. #14 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    That's what I have, but I just have the 1000.1D. 500 less watts RMS. Good solid amp for being a cheapy, as I said, the ***** doesn't get hot at all.
    http://www.amazon.com/Hifonics-HFi10...9315620&sr=8-1
    Plus the HFI on top glows a pretty blue. :P
  15. #15 Re: picking the right amp?
    Topeka, KS
    I've never heard anyone complain about the Hi-Fonics amps. I know alot of people that run the "Brutus" series.
  16. #16 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    The Brutus series is a great, higher end series as well. I've had issues with Power Acoustik amps which are also Maxxsonics amps, but the Hifonics series, even their "low end" HiFi series is great. Serious, I love mine.
  17. #17 Re: picking the right amp?
    Nov 2011
    Decatur
    thanks for the input guys! and im thinking that it makes a lot of sense to not put it on full blast because its a lot more stress on an amp to work at full power than half and so ill look into some of those amps. if you havent noticed i can be kinda slow.. haha. but yes thank you guys a lot for the help!
    EDIT: what others are good brands? hows JVC? and you said power acousik is terrible?
  18. #18 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    JVC, stay away. I personally had a bad experience with a power acoustik amp, but they're made by the same people that make Hifonics... the low end **** is well... ****, though.
  19. #19 Re: picking the right amp?
    Nov 2009
    illinois
    JVC headunits are good not sure on their amps however.
    i still believe your best bet is the mb quart amp i linked on the first page
  20. #20 Re: picking the right amp?
    Nov 2008
    Waterloo, Iowa
    Lol JVC headunits are for "cheap-getting-the-job-done" and such. I would never recommend one to someone that can afford a real headunit. 7-color changing lights don't make them "good" at all. :P
  1. Picking up a GTP
    By E90 87SS GTP in forum Introductions/Noob Questions
    Last Post: 09-26-2009, 05:22 PM
  2. Need Help Picking Car!!
    By cue244 in forum Off Topic Discussion
    Last Post: 07-03-2009, 06:14 AM
  3. Need help picking a project car : /
    By gdbyrd in forum Off Topic Discussion
    Last Post: 05-02-2009, 05:13 PM
  4. Picking a car
    By robahr24 in forum General Tech Discussion
    Last Post: 01-04-2009, 03:05 PM
  5. Been picking on new gen Mustang GT's
    By DesQ27 in forum Track Sessions and Kills
    Last Post: 10-14-2008, 11:52 PM
