Wiring them parallel will be easy seeing they're both SVC. Just wire them as you normally would and bridge them at the amp. Those are basically the same subs, except one is a series newer. Im not sure about the amp, because there is very limited details about it. Is the amp 300 x 2 or 150 x 2? Is that RMS or Peak? And at what load are those numbers 2 ohm or 4 ohm? I'd point you toward some amps, but Im not sure what your budget is.
