Thread: Woofer Position Question(update-new problems/ideas)
Results 1 to 20 of 74
  1. #1 Re: Woofer Position Question(update-Position is done with now on to more problems)
    i want i knob to control it,
    i use it everyday, some songs i want massive bass and other i dont and everything in between
    so i need one
    i have had the same set up for 4 years and everything still works and sounds like new
    only problem ive had is the bass knob thingy
    couple questions
    how do you know if the HU has sub control?
    my box is big and open and 1' thick mdf so what does it matter if one sub is out and the other is in?
    SMGPFC Member #10
  2. #2 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    so i need one
    couple questions
    Technically speaking, the kick of bass is determined by your mid speaker and how well it matches up with the sub. That means install and tuning are paramount! You can EQ your tweeter and change the sound of "bass"
    Go to an audio competition and listen to different setups. Notice their mid configuration in comparison to subs.
    11 is louder than 10!
  1. Cam Position Sensor
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 08-23-2011, 04:21 AM
  2. sub woofer pre amp out on factory Delco?
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2009, 10:10 AM
  3. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  4. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
