Thread: Cam Position Sensor
Results 1 to 8 of 8
  1. #1 Cam Position Sensor
    SE Level Member SilvrGrandPrixGT's Avatar
    Nov 2009
    Indiana
    Does anyone know where this is located? I looked online, but all I found was that it "was located above the crank pulley and to the lower left of the serpentine pulley". I am not seeing it. I was wondering if anyone knew where a diagram was...that would be helpful. The sooner the better!
  2. #2 Re: Cam Position Sensor
    GT Level Member RegalGS98s's Avatar
    NJ
    It's located right below the waterpump. Forget, but you may need to remove the water pump pulley (not the whole water pump) to access it.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: Cam Position Sensor
    Picture time
    Here it is upside down
  4. #4 Re: Cam Position Sensor
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    I have an OEM that I bought for my 04, if it fits your car you can have it for 50 shipped. Let me know
  5. #5 Re: Cam Position Sensor
    Quote Originally Posted by Javi View Post
    My car had the same issues and then it suddenly stopped.
    Same issue as what? I don't see an issue in this post. Just a "Where is this". Unless I'm missing something?
  6. #6 Re: Cam Position Sensor
    OKC, Oklahoma
    doh! my mistake, i meant to post that on the thread "shut off while driving"
  7. #7 Re: Cam Position Sensor
    I thought I missed soemthing and reread a couple times..lol
  8. #8 Re: Cam Position Sensor
    Nov 2009
    Indiana
    Thanks, Regal. That helps a lot.
  1. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  2. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  3. throttle position sensor
    Last Post: 12-25-2010, 11:16 AM
  4. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
  5. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
