Im not sure what pink wire you're talking about, unless its the factory amp turn on wire. But for the amp you just need the main power wire, remote line ( your HU harness will have that wire to connect to ), RCA's, Ground wire and you will need to run new speaker wires to the speakers. You wont be able to use the stock wire because they run through the stock amp.
