Thread: keep blowing fuse for fog lights.
Results 1 to 6 of 6
  1. #1 keep blowing fuse for fog lights.
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    hey im just wondering has anyone ever had a problem blowing the fuse for their fog lights? i have hid fog lights 4300k, i noticed it today and found the fuse was blown, again tonight when i turned on my lights the fogs didnt come on again and yep blown the fuse a second time today. the fuse is a 10a do you think there is any danger to put a 15amp fuse in there?
  2. #2 Re: keep blowing fuse for fog lights.
    Florida
    You shouldn't ever go above the factory rated fuse amperage, or you chance shorting out other components.
    Now, do you have the Relay Harness for those HIDs? If not, get it.
    Mine kept popping the fuse, got the relay harness (like $10 or so) and solved it.
  3. #3 Re: keep blowing fuse for fog lights.
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Could be shorting your fuse out too
  4. #4 Re: keep blowing fuse for fog lights.
    no i dont have the relay harness but ive had this kit installed for about 5 months now and its only happening now! so il try getting a relay harness but where can i get one and where do i install it? never heard of it.
  5. #5 Re: keep blowing fuse for fog lights.
    Florida
    From wherever you got your HIDs from.
    The other option, is to trace the wiring, and see if there are any frays.
    Install is plug and play.
  6. #6 Re: keep blowing fuse for fog lights.
    Charles City, IA
    You need a relay harness.
    SMGPFC Two Nipple General
  1. Help with blowing reverse fuse
    By ck115 in forum General Tech Discussion
    Last Post: 08-02-2010, 09:05 PM
  2. Keep blowing Injector fuse
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 07:40 AM
  3. Blowing MAF Fuse, SES Light, P0102
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 08:53 AM
  4. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
  5. keep on blowing fuel pump fuse
    By libster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2008, 09:25 PM
