the amperage of the fuse will(should) have no bearing if the power wire is shorted to ground. You say that all connections have tape wrapped around them, my question would be what type of connection are you using then? Proper connection should be soldered and heat shrink, Tape just has a habit of removing itself after time. I would recheck each and every connection to verify its validity.
