Thread: no power to headunit or amp??
Results 1 to 20 of 29
  1. #1 Re: no power to headunit or amp??
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    also the 10 amp fuse in the back of the radio was checked and good. the wire im using is 8 guage and been installed for only about 3 or 4 months tops and when we re-wired the power wire to the other side it looked perfectly fine
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: no power to headunit or amp??
    Houston
    Quote Originally Posted by mezzoni View Post
    The 8 gauge is your amp power wire, if it had a short in it, it would be popping the fuse by the battery, not the radio fuse. Did you use a wire harness when you installed the radio? If so, I'd completely remove the harness. Put in a new fuse and turn the key. If it doesnt pop, then your problem is the wiring from the Head unit to the wire harness.
  1. Headunit
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 09:41 PM
  2. New Headunit
    By DreadMcLaren in forum Audio, Security & Visual Electronics
    Last Post: 12-31-2010, 12:02 PM
  3. Headunit
    By Iceroyal in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2010, 08:43 PM
  4. 04+ headunit in a 97-03 gp?
    By shawn3091 in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2010, 05:23 PM
  5. Headunit Help
    By jack08 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2009, 07:00 PM
