Yeah I can give you a quick jist of what was involved. First of all, this took a whole summer and a fairly considerable amount of money, tears and blood to complete, so be warned. I started off be removing the deckled, and fiberglassing two layers over it for the back contour of the back. Then I removed it and trimmed it. I then made the MDF backbone to fit my components, mount to the trunk itself and create the center area for the plexiglass. Once that was done, I found out where the mounting holes would go by test fitting it on the decklid. Once I had my mounting holes, there were 4 of them, simply bolted through the MDF into Nut-certs in the trunk, I did the outer skin fiberglassing by hot glueing a piece of felt over the MDF skin and around the backside of the back fiberglass. I hardened it with fiberglass resin. Then finished it with bondo, and color matched charcoal felt. I mounted my speakers and used my laser etcher to etch the plexiglass. I lit the plexi using two blue LED strips. I ran wires to each of the 4 speakers and to the LED lights. I controlled the speakers and lights with a 4 Pole double throw relay which was actuated of the trunk latch. This relay turned the lights on and switched the output from my 4 channel amplifier from the rear deck to the trunk speakers. I think thats a quick overview of the project! I would be happy to go into more details if you want to know more! Good luck!
