Thread: Trunk Lid Speaker Install
Results 1 to 20 of 40
chamilton89 Trunk Lid Speaker Install 06-03-2011, 09:21 AM
chamilton89 Re: Trunk Lid Speaker Install 06-03-2011, 09:33 AM
chamilton89 Re: Trunk Lid Speaker Install 06-14-2011, 07:19 PM
chamilton89 Re: Trunk Lid Speaker Install 08-31-2011, 01:42 PM
chamilton89 Re: Trunk Lid Speaker Install 08-31-2011, 06:30 PM
PurpleGuy Re: Trunk Lid Speaker Install 08-31-2011, 06:32 PM
Slowpoke Re: Trunk Lid Speaker Install 08-31-2011, 06:33 PM
chamilton89 Re: Trunk Lid Speaker Install 08-31-2011, 06:35 PM
chamilton89 Re: Trunk Lid Speaker Install 08-31-2011, 06:34 PM
bobabooie Re: Trunk Lid Speaker Install 09-01-2011, 07:59 AM
NegativeOne13 Re: Trunk Lid Speaker Install 09-01-2011, 08:10 AM
Mad Monkey Re: Trunk Lid Speaker Install 09-01-2011, 09:02 AM
chamilton89 Re: Trunk Lid Speaker Install 09-01-2011, 01:09 PM
chamilton89 Re: Trunk Lid Speaker Install 09-21-2011, 09:37 AM
machinegunsquid Re: Trunk Lid Speaker Install 09-21-2011, 10:20 AM
Mad Monkey Re: Trunk Lid Speaker Install 09-21-2011, 10:34 AM
Taz Magister Re: Trunk Lid Speaker Install 09-21-2011, 10:37 AM
SlowNA06 Re: Trunk Lid Speaker Install 09-21-2011, 10:52 AM
chamilton89 Re: Trunk Lid Speaker Install 09-21-2011, 04:34 PM
chamilton89 Re: Trunk Lid Speaker Install 09-21-2011, 04:35 PM
SlowNA06 Re: Trunk Lid Speaker Install 09-22-2011, 10:25 AM
Hippo Machine Re: Trunk Lid Speaker Install 09-21-2011, 04:45 PM
Ricky21 Re: Trunk Lid Speaker Install 09-21-2011, 04:57 PM
rynoman03 Re: Trunk Lid Speaker Install 09-21-2011, 04:57 PM
burgundybullet Re: Trunk Lid Speaker Install 09-21-2011, 05:12 PM
I800C0LLECT Re: Trunk Lid Speaker Install 09-21-2011, 08:55 PM
cliffdawg Re: Trunk Lid Speaker Install 09-22-2011, 10:47 AM
Colossus Re: Trunk Lid Speaker Install 09-22-2011, 11:12 AM
chamilton89 Re: Trunk Lid Speaker Install 09-22-2011, 12:55 PM
2dee11 Re: Trunk Lid Speaker Install 06-08-2012, 11:07 PM
chamilton89 Re: Trunk Lid Speaker Install 06-09-2012, 11:44 PM
2dee11 Re: Trunk Lid Speaker Install 06-11-2012, 12:39 PM
chamilton89 Re: Trunk Lid Speaker Install 06-13-2012, 07:06 PM
2dee11 Re: Trunk Lid Speaker Install 06-16-2012, 11:50 PM
chamilton89 Re: Trunk Lid Speaker Install 06-17-2012, 01:32 AM
chamilton89 I know it's been a long time... 07-28-2012, 12:50 PM
chamilton89 Re: Trunk Lid Speaker Install 08-02-2012, 04:13 PM
chamilton89 Bump 08-15-2012, 09:32 AM
Mad Monkey Re: Trunk Lid Speaker Install 08-15-2012, 01:44 PM
chamilton89 Appreciate the advice. I've... 08-15-2012, 01:57 PM
  1. #1 Trunk Lid Speaker Install
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Ia am well underway in installing a set om component speakers underneath the trunk lid as well as a decorative piece in between the two sets. I will shift power from my amplifier using a relay to reroute power from my rear deck 6x9s to my trunk lid speakers when the trunk is open. This is a very ambitious project for me. So far I have fiberglassed the deck lid itself to create a mold and also created MDF mounting brackets to mount my speaker rings onto as well. I will post pictures asap of my progress any any ideas on what to put into the center ring, Which will be shown shortly from the pictures will be greatly appreciated. I think for now im going to use some gray vinyl and then put some sort of blue felt with Pontiac cut out of it. When I get back into school im going to use the laser cutter to engrave plexiglass and then use led back lighting to make it glow. Ill post some pictures of that as well.
    Infinity all around.
  2. #2 Re: Trunk Lid Speaker Install
    Here is a picture of my current setup and where I want to mount the speakers on the inside of the trunk:
    Here are two of my quick ideas on what to fill the center with. The top on is the vinyl route and the bottom is the engraved plexiglass:
  3. #3 Re: Trunk Lid Speaker Install
    Some new pictures:
    MD Backbone:
    MDF mounted to fiberglass:
  4. #4 Re: Trunk Lid Speaker Install
    Got finished up with all of the fiberglassing, bonding and carpeting and got the midranges installed and operational. There will be pictures to come. Next is to use a laser cutter and etch some plexiglass and work on the lighting and install the tweeters. Almost done. Pictures to follow.
  5. #5 Re: Trunk Lid Speaker Install
    Here are those pictures I promised.
    Here is after some bond and sanding, you can see how neat the contours turned out.
    The relay that controls the speaker output using the trunk switch. When the trunk is closed, power from the amplifier is sent to the rear 6x9's but when it is opened, it is rerouted to the trunk speakers. You can see the 4-pole double throw relay on the right that controls both speakers as well as two additional power sources which were wired to the trunk for further lighting.
    Here are two pictures of it carpeted and mounted with speakers which work wonderfully. Still need to mount the tweeters as well as etch the plexiglass that will go in the center opening.
  6. #6 Re: Trunk Lid Speaker Install
    Never Never Land
    Looks good. Looks nice. But why?
  7. #7 Re: Trunk Lid Speaker Install
    The dark side of the Moon
    Looks good, trunk rattle like a bauce tho.
    2004 Cobra
    2011 Mustang GT
    2013 F150 SCrew 5.0
  8. #8 Re: Trunk Lid Speaker Install
    Its not bad at all, two sealed subs with a small displacement makes a nice tight bass. Also the trunk speakers arnt on all the time, only when the trunk is open.
  9. #9 Re: Trunk Lid Speaker Install
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I was at a tailgate and my friends knew i had a decent system in my car so i was designated to play the music. After a few minutes I realized I was working my system pretty hard and that only the two front door speakers were facing the rear of the car, so I decided to take everyones trunk mat idea and spruce it up a bit.
  10. #10 Re: Trunk Lid Speaker Install
    Dec 2010
    Lancaster, OH
    Looks sweet! Nice work!
  11. #11 Re: Trunk Lid Speaker Install
    Kansas
    Hell yeah! You sir have done a good job so far.
  12. #12 Re: Trunk Lid Speaker Install
    London Ont, Canada
    Thats the way ya do it, only on when trunk up, but even then id have em on some kinda toggle switch, just so that someone doesnt get accidentally def from opening the trunk to get something one day lol
  13. #13 Re: Trunk Lid Speaker Install
    lol, you make a good point...I suppose too bad for them at this point. Im going to try and finish her up this week, ill continue to add pictures as I work on it.
  14. #14 Re: Trunk Lid Speaker Install
    Finally Done. Tell me what you think!
  15. #15 Re: Trunk Lid Speaker Install
    Florida
    /drool
    reminds me of my setup (excluding the trunk lid)
    Looks damn fine, extremely clean, and rather classy.
  16. #16 Re: Trunk Lid Speaker Install
    London Ont, Canada
    Love it!!
  17. #17 Re: Trunk Lid Speaker Install
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Ive never really been in to sound systems that much. The only thing I've ever done was 2 10" subs under the back seat in the truck lol. but what you got there is cool my freind
  18. #18 Re: Trunk Lid Speaker Install
    Pennsylvania
    Slammin'! I'd honestly install a volume/off knob in the back there attached to the speakers/tweeters so that you can leave it off or whatever. Though, I guess if you've got a remote for the headunit, that would work, too.
  19. #19 Re: Trunk Lid Speaker Install
    Quote Originally Posted by SlowNA06 View Post
    Yeah, I understand. Whats cool is that it works on a relay so basically when I open the trunk, the backlight for the plexiglass lights up and the speaker output for my 4 channel amp is switched from my rear 6x9's to me trunk speakers, all without me having to do a thing! Works really well and I am very happy with how it came out.
  20. #20 Re: Trunk Lid Speaker Install
    I appreciate very much all the support you few have given me. I have to thank those two guys who install the trunk lid mats, they are what gave me the spark to make this all happen.
  1. Running Speaker Wires from door to trunk
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2011, 09:36 AM
  2. Speaker Problum need help
    By Sesleeper in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2010, 01:18 PM
  3. Speaker ?
    By kassel98gt in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2009, 05:53 PM
  4. Speaker Help
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2008, 11:36 PM
  5. New speaker help
    By 98gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2008, 10:37 PM
