Thread: Trunk Lid Speaker Install
Results 1 to 20 of 40
  1. #1 Re: Trunk Lid Speaker Install
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Got finished up with all of the fiberglassing, bonding and carpeting and got the midranges installed and operational. There will be pictures to come. Next is to use a laser cutter and etch some plexiglass and work on the lighting and install the tweeters. Almost done. Pictures to follow.
    Infinity all around.
  2. #2 Re: Trunk Lid Speaker Install
    Here are those pictures I promised.
    Here is after some bond and sanding, you can see how neat the contours turned out.
    The relay that controls the speaker output using the trunk switch. When the trunk is closed, power from the amplifier is sent to the rear 6x9's but when it is opened, it is rerouted to the trunk speakers. You can see the 4-pole double throw relay on the right that controls both speakers as well as two additional power sources which were wired to the trunk for further lighting.
    Here are two pictures of it carpeted and mounted with speakers which work wonderfully. Still need to mount the tweeters as well as etch the plexiglass that will go in the center opening.
  1. Running Speaker Wires from door to trunk
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2011, 09:36 AM
  2. Speaker Problum need help
    By Sesleeper in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2010, 01:18 PM
  3. Speaker ?
    By kassel98gt in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2009, 05:53 PM
  4. Speaker Help
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2008, 11:36 PM
  5. New speaker help
    By 98gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2008, 10:37 PM
