Here are those pictures I promised.
Here is after some bond and sanding, you can see how neat the contours turned out.
The relay that controls the speaker output using the trunk switch. When the trunk is closed, power from the amplifier is sent to the rear 6x9's but when it is opened, it is rerouted to the trunk speakers. You can see the 4-pole double throw relay on the right that controls both speakers as well as two additional power sources which were wired to the trunk for further lighting.
Here are two pictures of it carpeted and mounted with speakers which work wonderfully. Still need to mount the tweeters as well as etch the plexiglass that will go in the center opening.
