Thread: Big 3 Electrical upgrade
Results 1 to 20 of 26
  1. #1 Big 3 Electrical upgrade
    wv
    Hey folks,
    I've recently installed an amplifier and subwoofer combo. Amplifier is the alpine mrp-m500 powering an mb quart rwe 304 DVC wired in parallel so it's pulling the max wattage. Under higher volume, my lights dim pretty badly with the bass hits. So, first step I'm taking is the big 3 upgrade.
    I was just wondering if anyone had some pics to share of their Big 3 upgrade, or knew a link of a Big 3 specific to an 04+ grand prix with the base 3.8l.
    Also, where is the engine ground to chassis ground on these?
    Any tips or other advice on this is helpful. I know it's pretty straight forward, alternator + to battery +, battery - to chassis, and engine ground to chassis ground. I've never done it before and would like to see some additional info/pictures on a similar vehicle so I can go in it with more confidence.
    I've already purchased 2AWG wiring to do this with. I've got 4ft of power and 6ft of ground to work with. Also, I plan on bypassing the stock wiring so I was wondering what size in-line fuse would be recommended. Alternator is 125A so I was thinking 150, or 160A for the fuse?
    Thanks in advance.
  2. #2 Re: Big 3 Electrical upgrade
    Redo your grounds.
    Proper "Big 3" for our cars is really a "big 5"
    Just redo your grounds and connections.
  3. #3 Re: Big 3 Electrical upgrade
    Pennsylvania, USA
    Not trying to revive a dead thread, but what are the big 5 in 04+?
    I found
    battery+ to alternator+
    battery- to chassis
    battery+ to fusebox
    battery- to engine (I think)
    I can't find the engine to chassis at all, and I'm not even completely sure that the battery+ to fusebox even counts...
  4. #4 Re: Big 3 Electrical upgrade
    GT Level Member jmoore4294's Avatar
    Alternator to fuse box.
  5. #5 Re: Big 3 Electrical upgrade
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by nik12937 View Post
    I found
    battery+ to alternator+ YES
    battery- to chassis YES
    battery+ to fusebox OP
    battery- to engine (I think) wrong engine to chassis
    Quote Originally Posted by jmoore4294 View Post
    Alternator to fuse box. uhh no
    1st off its all FAIL
    500W amp @2ohm your wired at 2ohm this is good
    what are your settings on your amp:
    Gain:
    Bass EQ:
    Low Pass Filter:
    that info will solve your problem
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  6. #6 Re: Big 3 Electrical upgrade
    wv
    Quote Originally Posted by 1LoudGrandPrix View Post
    Gain:
    Bass EQ:
    Low Pass Filter:
    Gain = 75%
    Bass boost on amp (50hz) is +5 out of 12
    Graphic equalizer, 80hz +4, 100hz +4
    Bass booster on the deck is as low as it goes
    No low pass filter is set
  7. #7 Re: Big 3 Electrical upgrade
  8. #8 Re: Big 3 Electrical upgrade
    Feb 2009
    Virginia
    I think I was the asshole in that thread...so don't forget to read my comments!
    And op...Matt is right. Turn the gains down!!!! Nice tight bass is a product of good integration between the subs and your mids. Otherwise you're doing it wrong and it's boom boom with NO snap at all. Matter of fact, it can end up cancelling a lot of the mid-bass and you'll get headaches or ear fatigue.
    A well tuned system cranks and doesn't cause any discomfort for anybody.
    11 is louder than 10!
  9. #9 Re: Big 3 Electrical upgrade
    Cedar Rapids, IA
    once you post a score with a TL in the legal position with a score higher than 148 with no more than 2020W we will talk or if you want less wattage try 147.8 @1688W
    regardless you don't need a HO alt for 500 watts
    explain to me how we could get 3kw out of shanes car with stock alt?
  10. #10 Re: Big 3 Electrical upgrade
    all that gain is bad.
    turn the bass boost off, and the EQ.
  11. #11 Re: Big 3 Electrical upgrade
    wv
    Wouldn't this only result in my having to turn the volume up higher to get the same result, and inevitably, the same dimming problem?
    I like the way my stereo sounds now as is. I can keep the volume low and still feel the bass, and if I wanna jam I can do that too. I listen to music mostly at a normal level, but I do admit I get a wild hair every now and then.
    Although I have contemplated turning the gain down on the amplifier a bit. Somwhere between 50 and 75% probably. This is a 500Wrms Sub, and a 500Wrms amp.
    I will experiment more with my bass boost and EQ adjustments though and see if I may be able to find a compromise in the works somewhere. thanks for the advice
  12. #12 Re: Big 3 Electrical upgrade
    Your gains should be adjusted properly as well.
    If that doesnt result in enough "boom", you need a better setup seeing as something is missing.
  13. #13 Re: Big 3 Electrical upgrade
    wv
    seeing as the gain is already 3/4 of the way up, there isn't much more room i could go. i guess i could knock of the eq and bass boost while increasing gain to near 100%?
    If I did so would this help minimize my dimming problem?
  14. #14 Re: Big 3 Electrical upgrade
    Pennsylvania, USA
    battery- to chassis
    battery+ to fusebox
    engine to chassis
    What is the final one to make it five? jmoore and that link said alternator to fusebox, but 1Loud you said no.
    I just want to make sure I get everything right the first time so I don't have to go back again when I finally find someone who makes a god damn HO alternator for a 2005.
    Extra info: I'm running 900 watts to two original (and I mean original) L7's (they're surprisingly accurate until you crank it, then classic Kicker poo) with a 5 farad cap (I don't care if I don't need it, I get too many mixed responses). At max volume I get slight dimming, and as weird as it sounds, my transmission slips... not sure why, but I'm completely sure after a few tests that low voltage is the cause. So I'm hoping the Big 3 (Big 5) will help.
  15. #15 Re: Big 3 Electrical upgrade
    Cedar Rapids, IA
    make sure the ground on your trans is clean then
    reason why i say no: if your power wire is to the batt then the wire to the fuse box has no more load then with out a system
    also when you crank it are you sure its not the box peaking out? cap = extra weight lol
    OP: what HU you have? model and everything
    also make everything flat no boost at all
    your gain should be set to the voltage that the HU is feeding the rcas
    just becouse its wired to 2ohm dose not mean its seeing 2 ohm your gotta take in effect rise IE: my Aqs where wired down to 1 ohm but when mettered showed 2.66 on 1 amp keep in mind that was a test tone music the ohm load will change alot depending on the note and how the sub and box react to that freq.
  16. #16 Re: Big 3 Electrical upgrade
    Pennsylvania, USA
    I'll try my best to get to the tranny's ground, I bet it'll be a *****... I'm getting it looked at this monday either way too, better to check than let it go and have it get worse right?
    So as for the Big three, I guess I can leave out the fusebox, but what about that 5th wire? I'm still unsure as to what that could be.
    And when I max my volume on my HU (I keep it safe at 30 out of 35) I'm pretty sure my amp isn't even putting out all 900 watts because I just adjusted my gains until my lights started dimming, and no distortion (at least none in addition to the distortion all square woofers seem to have).
    I'd also like to get rid of the cap, but it really helped reduce my headlight dimming when I put it in, whether it was the cap or the extra ground. So maybe if rewiring helps as much as I hope it does.
  17. #17 Re: Big 3 Electrical upgrade
    Topeka, KS
    What's the max a guy should turn his gain upto? And Also i wasn't aware that a person shouldn't use bass boost on the amp. I'll turn this down when I get home. I think i have my sub set to +3 on the HU. Are you guys saying not to up that as well ?
  18. #18 Re: Big 3 Electrical upgrade
    Never Never Land
    Like 25%ish percent or basically turn the system up fairly loud. Like 75-80% and then turn the gain up until it starts distorting Distortion will kill your subs. Doesnt matter if your runnin 100 watts or 1000 watts. My gain is set all the way down I have NO gain at all. I can go up 12DB but I leave it done soley for the purpose of avoiding distortion
  19. #19 Re: Big 3 Electrical upgrade
    Topeka, KS
    Gotcha. I'll have to play with my settings sometime.
  20. #20 Re: Big 3 Electrical upgrade
    You're supposed to set it with an oscilloscope but no one owns one....
  1. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  2. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  3. Electrical
    By Brandan2670 in forum General Tech Discussion
    Last Post: 03-30-2009, 01:52 PM
  4. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
