Thread: Big 3 Electrical upgrade
Results 1 to 20 of 26
  1. #1 Re: Big 3 Electrical upgrade
    GT Level Member jmoore4294's Avatar
    Alternator to fuse box.
  2. #2 Re: Big 3 Electrical upgrade
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by nik12937 View Post
    Not trying to revive a dead thread, but what are the big 5 in 04+?
    I found
    battery+ to alternator+ YES
    battery- to chassis YES
    battery+ to fusebox OP
    battery- to engine (I think) wrong engine to chassis
    I can't find the engine to chassis at all, and I'm not even completely sure that the battery+ to fusebox even counts...
    Quote Originally Posted by jmoore4294 View Post
    Alternator to fuse box. uhh no
    1st off its all FAIL
    500W amp @2ohm your wired at 2ohm this is good
    what are your settings on your amp:
    Gain:
    Bass EQ:
    Low Pass Filter:
    that info will solve your problem
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  3. #3 Re: Big 3 Electrical upgrade
    wv
    Quote Originally Posted by 1LoudGrandPrix View Post
    Gain:
    Bass EQ:
    Low Pass Filter:
    Gain = 75%
    Bass boost on amp (50hz) is +5 out of 12
    Graphic equalizer, 80hz +4, 100hz +4
    Bass booster on the deck is as low as it goes
    No low pass filter is set
  1. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  2. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  3. Electrical
    By Brandan2670 in forum General Tech Discussion
    Last Post: 03-30-2009, 01:52 PM
  4. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
