all that gain is bad.
turn the bass boost off, and the EQ.
Wouldn't this only result in my having to turn the volume up higher to get the same result, and inevitably, the same dimming problem?
I like the way my stereo sounds now as is. I can keep the volume low and still feel the bass, and if I wanna jam I can do that too. I listen to music mostly at a normal level, but I do admit I get a wild hair every now and then.
Although I have contemplated turning the gain down on the amplifier a bit. Somwhere between 50 and 75% probably. This is a 500Wrms Sub, and a 500Wrms amp.
I will experiment more with my bass boost and EQ adjustments though and see if I may be able to find a compromise in the works somewhere. thanks for the advice
