The headlight DRL's on 04+ Grand Prix's are controlled by the BCM. Now, you can turn off the DRL's by turning off the auto headlight feature on the headlight switch on the turn signal stalk. That's what I do. I run a relay harness and if I leave the DRL's on the relay buzzes because it isn't getting the correct amount of voltage to keep the relay coil properly energized.
