Thread: Disabling DRL's in a 04+
Results 1 to 20 of 27
  1. #1 Disabling DRL's in a 04+
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    anyone know how to disable the DRL's in a '06 GT ?
    I just installed my HID fogs yesterday and now when my DRL's are on, the low beams flicker really fast and buzz...
    Called DDM tuning and they said it was normal with DRL's. I have low beam HID's and fogs, both with wiring harness ( low beams didn't do this before fog install ).
    Anyways I need to disable the DRL's, anyone know how? Besides pulling the fuse?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Disabling DRL's in a 04+
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Did you have to put in a special houseing for the fogs? It was my understanding HIDs got to hot for stock housings
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: Disabling DRL's in a 04+
    GTX Level Member Confusingboat's Avatar
    Minnesota
    It shouldn't be normal if you have the relay harness because it gets full power when turned on no matter how much power switched on the relay.
    Try unhooking the fogs and see if they do it then. And clean your battery terminals and tighten them.
    Do you have DRL low beams or DRL signals?
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  4. #4 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    no, HID's are fine in housings, they don't get that hot.
    they were just cleaned and tightened. DRL's are trying to draw more power than is there...
    and I have DRL lows...
    I just wanna know how to disable DRL's without pulling the fuse's please...
  5. #5 Re: Disabling DRL's in a 04+
    MO
    Wasn't it the 06+ that had low beam DRL's vs. fogs? I saw something in the past saying some company's HID's wouldn't work for the 06
    <brandonl2000> LMAO D!!
  6. #6 Re: Disabling DRL's in a 04+
    Minnesota
    Hmm. Perhaps get a relay that closes with less power? That way even the lower power DRLs can effectively switch on the relay.
    2015 Evo MR
  7. #7 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    any update on this ? BUMP...
    I'm ready to pull the fuse now but cannot locate one, couldnt find it in the fuse box, inside the car or under the hood.
  8. #8 Re: Disabling DRL's in a 04+
    Arizona
    from my understanidng 06 and up have no fuse, its progammed or something.
    '00 GT- nothing special
  9. #9 Re: Disabling DRL's in a 04+
    GT Level Member RedDawnGXP's Avatar
    Indiana
    The headlight DRL's on 04+ Grand Prix's are controlled by the BCM. Now, you can turn off the DRL's by turning off the auto headlight feature on the headlight switch on the turn signal stalk. That's what I do. I run a relay harness and if I leave the DRL's on the relay buzzes because it isn't getting the correct amount of voltage to keep the relay coil properly energized.
  10. #10 Re: Disabling DRL's in a 04+
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    One way I have mine disabled that if you only have your turn signal lights on (on the headlight switch) that they will shut off after about 5 minutes after your car shuts off so in a way it disables the DRls for your low beams.
  11. #11 Re: Disabling DRL's in a 04+
    Jul 2008
    Tampa, FL
    i put a piece of cloth over the sensor, and just manually turn the HID's off if i don't want them on...idk if this is the best way, but its how i have it until someone figures out a better method...
  12. #12 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    ^^^eeek I duno about that...we'll I guess i'll just be annoyed by manually turning my healights on ALL the time, even daylight...although during daylight, turning the fogs on, disables DRL but then i'm riding around with fog lamps on :\
    where is the sensor BTW? might try it cause at night, it doesn't buzz or blink....I have HID harness's on lows and fogs, didn't do this with lows only. issue started when I did the fog install ( which looks awesome BTW ).
  13. #13 Re: Disabling DRL's in a 04+
    Nov 2009
    Quote Originally Posted by offroadfury6 View Post
    Just turn on your turn signal lights.
  14. #14 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by csssaint12 View Post
    yeah but thats a pain and i'll always have to do this, looking for a pernament fix where I won't have to do this anymore.
  15. #15 Re: Disabling DRL's in a 04+
    Nov 2009
    You would only have to do it at night
  16. #16 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    I found this: BACKINBLACK's Grand Prix electrical modifications
    But he doesn't say where this part is located on the car.
  17. #17 Re: Disabling DRL's in a 04+
    Minnesota
    I'd just cover the sensor with some electrical tape. Not like it'd be noticeable.
    2015 Evo MR
  18. #18 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Confusingboat View Post
    alright bro, wheres the sensor? =P....you've seemed to be the most reponsive...tell me! and I'll give ya a thanks
  19. #19 Re: Disabling DRL's in a 04+
    Nov 2009
    no more thanks, just likes
  20. #20 Re: Disabling DRL's in a 04+
    Aug 2008
    Fayetteville, NC
  1. Disabling Cat Diagnostics
    By Bedwards in forum PCM Tuning
    Last Post: 11-24-2010, 12:07 AM
  2. tcc lockup disabling???
    By 513yj in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 10:08 AM
  3. Completely Disabling ABS?
    By SuperSport in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2009, 12:03 AM
  4. disabling auto headlights
    By Jakegday in forum General Tech Discussion
    Last Post: 11-15-2008, 01:23 PM
  5. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
