have a weird problem, half the time after starting the engine the fog lights wont turn on. flick the switch and sometims they will come on after that, some times they will not come back on for days. I took everything apart last weekend to look for loose connections and breaks in the wires. found nothing wrong. i do have a relay harness. but every time i try to check it out the fog lights start working again so i cant go around with a test light. its getting annoying! anyone had a problem like this before? also sometimes after starting the engine only 1 fog light will come on, if i flick the high beams or the fog light switch the other will come on. i have no idea whats going on.
