Well...I'm that guy always changing equipment...
So I've done some things and definitely changed my install. I haven't finished but it will be a dramatic change. I'll start with the amp that will run the entire system.
Zed's Leviathan
* High performance full range class D amplifier
* 6,5,4 or 3 Channel amplifier
* 150w x 6 at 4 ohm
* 24dB/octave Linkwitz-Riley crossovers
* Burr Brown ICs in the preamplifiers
* Ch1+2 High Pass crossover
* Ch3+4 High and Low Pass crossovers
* Ch5+6 Low Pass and subsonic crossover
* Ultra high efficiency with smart power supply
Zed Audio Corporation
I somewhat finished the doors too...still need Closed Cell Foam.
<b>w/o Hushmat</b>
<b>with Hushmat</B>
I plan on wrapping my A pillars in vinyl right now but we'll see what happens. I'd like to do myself even...
I also put some random Dynamat I had laying around around the underside of the speaker where it attaches to the baffle. Then I used extruded butyl on the baffle to make sure I had a tight seal.
I wonder if I could model something for that fiberglass enclosure?
