Thread: Changing my Audio Install
Results 21 to 40 of 40
Threaded View
  1. #1 Changing my Audio Install
    Feb 2009
    Virginia
    Well...I'm that guy always changing equipment...
    So I've done some things and definitely changed my install. I haven't finished but it will be a dramatic change. I'll start with the amp that will run the entire system.
    Zed's Leviathan
    * High performance full range class D amplifier
    * 6,5,4 or 3 Channel amplifier
    * 150w x 6 at 4 ohm
    * 24dB/octave Linkwitz-Riley crossovers
    * Burr Brown ICs in the preamplifiers
    * Ch1+2 High Pass crossover
    * Ch3+4 High and Low Pass crossovers
    * Ch5+6 Low Pass and subsonic crossover
    * Ultra high efficiency with smart power supply
    Zed Audio Corporation
    I somewhat finished the doors too...still need Closed Cell Foam.
    <b>w/o Hushmat</b>
    <b>with Hushmat</B>
    I plan on wrapping my A pillars in vinyl right now but we'll see what happens. I'd like to do myself even...
    I also put some random Dynamat I had laying around around the underside of the speaker where it attaches to the baffle. Then I used extruded butyl on the baffle to make sure I had a tight seal.
    11 is louder than 10!
  1. FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
    By ivorywhiteRIC in forum Audio, Security & Visual Electronics
    Last Post: 04-05-2015, 08:16 AM
  2. Changing rad
    By alexo1us in forum Buick Regal
    Last Post: 09-21-2010, 09:23 AM
  3. Tried changing the S/C oil...
    By tayl5645 in forum General Tech Discussion
    Last Post: 09-02-2010, 08:05 AM
  4. Changing SC Oil.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-03-2010, 11:58 PM
