Ive been all over the net looking for the factory monsoon system diagram. Im trying to connect LOC (line output converter) to the rear speakers in my 07 GP GT. But i could not find the diagram anywhere and the proper wiring color codes. This is now in the past as I have found and sharing with anyone who needs it (anyone with a Monsoon factory system, on-star, etc. will).
The proper procedure: Take your LOC and connect two of the wires to the left speaker (Audio Amp C2) using 5,6 (Yellow and brown) and for the right 7,8 (light blue, dark blue). Once connected plug up some RCA jacks to the LOC and the other end to your system. Then for switched12v remote use Audio Amp C1 the number 6 pink wire. And for the power and ground use the cars power as usual cause if you try to use the ones from the monsoon amp it will be to much power drawn, so run your power wire from amp to the battery and ground wire to the chassis (bolt down good!).
Factory Monsoon wiring diagram? - Hummer Forums - Enthusiast Forum for Hummer Owners
Audio Amp C1
1-TN-Left Front Low Level Audio Signal (+)
2-D.GN-Left Front Low Level Audio Signal (-)
3-D.GN/WH-Left Rear Low Level Audio Signal (-)
4-BN-Left Rear Low Level Audio Signal (+)
5-OG-Radio Mute Signal
6-PK-Radio On Signal
7-Not Used
8-GY/BK-Remote Amp Sense Line Signal
9-OG/BK-Right Front Low Level Audio Signal (-) / D.BU in early models
10-L.GN-Right Front Low Level Audio Signal (+)
11-D.BU-Right Rear Low Level Audio Signal (+) / OG/BK in early models
12-BK-Right Rear Low Level Audio Signal (-)
13 to 16-Not Used
Audio Amp C2
1-BK-Left Front Tweeter Speaker Output (+)
2-YE-Left Front Tweeter Speaker Output (-)
3-L.GN-Right Front Tweeter Speaker Output (+)
4-PU-Right Front Tweeter Speaker Output (-)
5-YE-Left Rear Speaker Output (-)
6-BN-Left Rear Speaker Output (+)
7-L.BU-Right Rear Speaker Output (-)
8-D.BU-Left Rear Speaker Output (+)
9 to 12-Not Used
13-L.GN-Right Front Speaker Output (+)
14-D.GN-Right Front Speaker Output (-)
15-TN-Left Front Speaker Output (+)
16-GY-Left Front Speaker Output (-)
Audio Amp C3
1-OG-Battery Positive Voltage
2-BK/WH-Ground
3-D.BU/WH-Left Subwoofer Speaker Output (+)
4-L.GN/BK-Left Subwoofer Speaker Output (-)
5 to 6-Not Used
7-L.BU/BK-Right Subwoofer Speaker Output (-)
8-L.BU/BK-Right Subwoofer Speaker Output (+)
On the radio should be a 24-pin connector (2-rows (A and B) of 12)
B1-OG-Battery Positive Voltage [I believe this is constant and not switched]
B3-PK-Radio On Signal (not 12v)
B6-OG-Radio Mute Signal (not 12v)
TOOK ME LONG ENOUGH TO PUT UP MY FIRST POST HERE... Popped my Cherry
