Thread: Front Speaker Replacement
Results 1 to 13 of 13
  1. #1 Front Speaker Replacement
    Feb 2010
    nj
    I have a 1999 Grand Prix 4 door sedan. Any instructions on how to change the door and sail panel speakers?
    Also, is there a specific ohm and power requirements to look for. I am not changing the radio, just replacing the speakers.
    Thanks for any help in advance.
  2. #2 Re: Front Speaker Replacement
    Front: Remove torx bolts behind door handles then pull the door skin off. Rest should be self explanatory.
    Rear: Remove bottom of rear seats by pulling on the plastic tabs, one behind each front seat.
    Undo the five 18 mm bolts/nuts holding the back seat in. Push the back seat up, it'll come out then. then pull the massive carpeted thing covering the speakers off. Might be some of those stupid plastic Christmas trees in there holding it in.
  3. #3 Re: Front Speaker Replacement
    GT Level Member josemolina2008's Avatar
    Modesto, Ca.
    I wonder why they made it so hard to get to the speakers and you also gotta do that to change the bulbs for the 3rd brake light.
    GP is gone...
  4. #4 Re: Front Speaker Replacement
    Cant you just side the thing apart from the bottom for the bulbs?
  5. #5 Re: Front Speaker Replacement
    Modesto, Ca.
    Wow you don't know how much of an a$$ you just made me feel lol. I just checked right now and there is a little door in the trunk.
    GP is gone...
  6. #6 Re: Front Speaker Replacement
    hey, at least it'll save you time in the future.
  7. #7 Re: Front Speaker Replacement
    Modesto, Ca.
    Yes it will man i feel dumb
    GP is gone...
  8. #8 Re: Front Speaker Replacement
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I went to replace tnhe front speakers and noticed the upper door tweeter was directly soldered to the original speaker. Can I replace the main door speaker and hook the tweeter back up? I guess I just need to splice it in? Is that what most of you do? Was there any high pass filter on the orginal speaker that went to the tweeter?
    Is there a replacement speaker for the tweeter?
  9. #9 Re: Front Speaker Replacement
    There is a cap inline with the tweeter, that is the first order filter. its needed.
    just wire it in parallel if you're using the stock head unit and it'll be fine.
  10. #10 Re: Front Speaker Replacement
    Feb 2008
    Quote Originally Posted by andremike View Post
    I just replaced my front speakers this weekend with brand new original parts. The tweeter has a plug that plugs into the door speaker. If yours is different then somebody messed something up. (EDIT: Also, mine is a 97, your 00 might be different)
    I looked for stock (AC Delco) for easy install. I didn't want to worry about splicing and different connectors.
    Here is a link to where I got my speakers from. Be patient, as this website can be difficult to navigate. ACDelco and Motorcraft Auto Parts OE Parts Headquarters -
    Hope this helps you out
  11. #11 Re: Front Speaker Replacement
    Feb 2008
    Quote Originally Posted by josemolina2008 View Post
    ....It happens to us all sometimes, no biggy!
  12. #12 Re: Front Speaker Replacement
    Nov 2009
    chicago
    Yes I am using the stock head unit... I cut the tweeter right at the main door speaker so the filter must be inline with the wire.. I'll have to splice the wire since I bought the easy connectors that go from the stock connector to the new after marktet speaker..
  13. #13 Re: Front Speaker Replacement
    splice 'er in then and go.
  1. Bose speaker replacement
    By shawngtp in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2010, 07:21 PM
  2. Speaker Replacement
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2010, 10:00 PM
  3. Front Speaker Installation
    By SuperCharged0nE in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2009, 10:28 AM
  4. Front Speaker Problems
    By Justin33 in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 06:46 PM
  5. Front Speaker Installation
    By justme in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2009, 03:27 PM
