Thread: Front Speaker Problems
Results 1 to 5 of 5
  1. #1 Front Speaker Problems
    Rock Rapids IA
    My front 5 1/4 speaker on the passanger door doesnt stay at the same volume, and sometimes it rattles when your driving. It will stay at the regular volume then suddenly drop volume, then go up for a bit. Its a Bose speaker and a buddy said that it might just be loose or a wire came disconnected. Anyone else have this happen or heard of it?
  2. #2 Re: Front Speaker Problems
    London Ont, Canada
    he's right, its probably a loose wire/loose speaker.
    time to tear it apart and check lol
  3. #3 Re: Front Speaker Problems
    Willoughby, Ohio
    its a loose wire if it is cutting out.. getting quieter and louder could be an amp (not sure if these bose systems come amplified) or the head unit.. most likey its the wires tho
  4. #4 Re: Front Speaker Problems
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    well the rattle you hear is probably the voice coil and the reason its fading is because the impedence on a blown speaker flucuates badly . Still running the stock deck?
  5. #5 Re: Front Speaker Problems
    Rock Rapids IA
    Sorry its been a while since i posted! I took the headunit out and re connected all the wires and that seems to have done the trick! Thanks for the suggestions!
  1. Front Speaker Installation
    By justme in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2009, 03:27 PM
  2. Speaker Problems
    By Pontiac Warrior in forum Audio, Security & Visual Electronics
    Last Post: 05-08-2009, 06:54 AM
  3. Replies: 2
    Last Post: 04-06-2009, 12:37 PM
  4. Help!!! Trans,Front End,Secondary air injection PROBLEMS!!!!!
    By 00gpgt in forum General Tech Discussion
    Last Post: 04-02-2009, 08:56 PM
  5. Door Chime/Speaker Problems
    By JBmiddy23 in forum General Tech Discussion
    Last Post: 12-20-2008, 10:46 AM
