Thread: Amp power wire help!!!!!
Results 1 to 20 of 30
Threaded View
Goldoni Amp power wire help!!!!! 12-10-2009, 02:15 PM
matt5112 Re: Amp power wire help!!!!! 12-10-2009, 02:57 PM
JarenSTi Re: Amp power wire help!!!!! 12-10-2009, 02:59 PM
matt5112 Re: Amp power wire help!!!!! 12-10-2009, 03:04 PM
JarenSTi Re: Amp power wire help!!!!! 12-10-2009, 03:11 PM
offroadfury6 Re: Amp power wire help!!!!! 12-11-2009, 10:03 AM
whiney Re: Amp power wire help!!!!! 12-11-2009, 11:51 AM
BlackJack Re: Amp power wire help!!!!! 04-24-2010, 07:33 AM
Bueller Re: Amp power wire help!!!!! 12-11-2009, 12:58 PM
offroadfury6 Re: Amp power wire help!!!!! 04-27-2010, 03:22 AM
whiney Re: Amp power wire help!!!!! 04-27-2010, 09:19 AM
offroadfury6 Re: Amp power wire help!!!!! 04-27-2010, 10:52 PM
ZR1Vette09 Re: Amp power wire help!!!!! 04-29-2010, 11:37 AM
gtpinsc Re: Amp power wire help!!!!! 04-24-2010, 08:57 AM
matt5112 Re: Amp power wire help!!!!! 04-24-2010, 03:56 PM
whiney Re: Amp power wire help!!!!! 04-24-2010, 05:09 PM
BlackJack Re: Amp power wire help!!!!! 04-24-2010, 07:26 PM
matt5112 Re: Amp power wire help!!!!! 04-27-2010, 09:44 PM
whiney Re: Amp power wire help!!!!! 04-27-2010, 11:48 PM
dagger Re: Amp power wire help!!!!! 04-28-2010, 07:48 AM
offroadfury6 Re: Amp power wire help!!!!! 04-28-2010, 09:52 PM
matt5112 Re: Amp power wire help!!!!! 04-29-2010, 11:52 AM
BlackJack Re: Amp power wire help!!!!! 05-01-2010, 09:24 AM
coreygnar Re: Amp power wire help!!!!! 05-01-2010, 02:17 PM
casper129 Re: Amp power wire help!!!!! 05-03-2010, 07:24 AM
BlackJack Re: Amp power wire help!!!!! 05-04-2010, 05:30 AM
matt5112 Re: Amp power wire help!!!!! 05-03-2010, 01:08 PM
coreygnar Re: Amp power wire help!!!!! 05-06-2010, 10:58 PM
I800C0LLECT Re: Amp power wire help!!!!! 05-06-2010, 11:18 PM
casper129 Re: Amp power wire help!!!!! 05-07-2010, 08:00 AM
  1. #1 Amp power wire help!!!!!
    Boston
    I have been trying to run an amp power wire for about 2 hours now. I tired running the wire thru a grommet on the drivers side but gave up on that. From what I've read on the forum it's alot easier to run it under the glovebox on the passenger side. I located the grommet under the hood but am not sure where its located in the interior. Is the picture below what I need to slice into in order to feed the wire thru? If not where exactly is this grommet located in the interior? Thanks!
    Amp power wire help!!!!! Attached Images
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  3. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
