Thread: Amp power wire help!!!!!
Results 1 to 20 of 30
  1. #1 Re: Amp power wire help!!!!!
    SE Level Member Bueller's Avatar
    Nov 2009
    I just did this last week. Take a needlenose or whatever you can to pull that square plug out. Once thats out take a knife and notch a bigger hole for your power wire to fit through. Then tape a clothes hanger to the wire and push it through that thin boot behind where the plug goes. Then just find it and feed up up away from the belt and your done.
  2. #2 Re: Amp power wire help!!!!!
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Bueller View Post
    not trying to get into a pissing contest but I dont understand why u guys would even take the rubber boot out. must be a 97-03 model?
    then again it's not that big of a deal soooo...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #3 Re: Amp power wire help!!!!!
    swift current,sask.
    Quote Originally Posted by offroadfury6 View Post
    It's just big enough to fit the wires that are already going through it. No way you would fit a run of sub wire without notching it out.
  4. #4 Re: Amp power wire help!!!!!
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by whiney View Post
    maybe thats a small 97-03 issue cause my 06, I just jabbed it with a screwdriver and stretched it, took 20 secs.
  5. #5 Re: Amp power wire help!!!!!
    MO
    passenger or driver side? i haven't looked yet but in the next couple weeks i'll be doing one
    <brandonl2000> LMAO D!!
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  3. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
