Thread: Amp power wire help!!!!!
Results 1 to 20 of 30
  1. #1 Amp power wire help!!!!!
    Boston
    I have been trying to run an amp power wire for about 2 hours now. I tired running the wire thru a grommet on the drivers side but gave up on that. From what I've read on the forum it's alot easier to run it under the glovebox on the passenger side. I located the grommet under the hood but am not sure where its located in the interior. Is the picture below what I need to slice into in order to feed the wire thru? If not where exactly is this grommet located in the interior? Thanks!
    Amp power wire help!!!!! Attached Images
  2. #2 Re: Amp power wire help!!!!!
    thats it buddy, you need to take off the plastic trim around the door to get the carpet up then you can see it right under the glovebox.
    Three screws, maybe four, but only one plastic piece.
    On the engine side of the firewall theres a thin plastic boot you'll need to get through, just poke it with a screwdriver and push it through there.
  3. #3 Re: Amp power wire help!!!!!
    its AWDsome JarenSTi's Avatar
    Hawaii
    or u can feed it through the door
    but thats the biggest pain in the ass
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  4. #4 Re: Amp power wire help!!!!!
    Quote Originally Posted by 02gpgt88 View Post
    ? the door goes into the lower section of the dash.
  5. #5 Re: Amp power wire help!!!!!
    Hawaii
    i didnt need to unscrew any little plastic piece
    just the door trim goin to the backseat/trunk
    2005 Subaru WRX
    2002 GT - sold
  6. #6 Re: Amp power wire help!!!!!
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i dont see why u couldnt get it through the boot in the firewall. u gotta take a screw driver and stretch that hole :P
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  7. #7 Re: Amp power wire help!!!!!
    swift current,sask.
    Just make sure you put that rubber thingy back in. Simple as that.
  8. #8 Re: Amp power wire help!!!!!
    Cleveland
    Quote Originally Posted by whiney View Post
    Sorry to revive the thread, but I'm working on the same project and I was wondering if you could be a little more detailed about where that is, do I have to look under the car because I can't seem to find it! Thanks!
  9. #9 Re: Amp power wire help!!!!!
    SE Level Member Bueller's Avatar
    Nov 2009
    I just did this last week. Take a needlenose or whatever you can to pull that square plug out. Once thats out take a knife and notch a bigger hole for your power wire to fit through. Then tape a clothes hanger to the wire and push it through that thin boot behind where the plug goes. Then just find it and feed up up away from the belt and your done.
  10. #10 Re: Amp power wire help!!!!!
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Bueller View Post
    not trying to get into a pissing contest but I dont understand why u guys would even take the rubber boot out. must be a 97-03 model?
    then again it's not that big of a deal soooo...
  11. #11 Re: Amp power wire help!!!!!
    swift current,sask.
    Quote Originally Posted by offroadfury6 View Post
    It's just big enough to fit the wires that are already going through it. No way you would fit a run of sub wire without notching it out.
  12. #12 Re: Amp power wire help!!!!!
    Aug 2008
    Fayetteville, NC
    maybe thats a small 97-03 issue cause my 06, I just jabbed it with a screwdriver and stretched it, took 20 secs.
  13. #13 Re: Amp power wire help!!!!!
    MO
    passenger or driver side? i haven't looked yet but in the next couple weeks i'll be doing one
    <brandonl2000> LMAO D!!
  14. #14 Re: Amp power wire help!!!!!
    Jul 2008
    sumter,south carolina
    pull carpet out from under dash area... cant miss it... little black rubber grommet.
    02 GTP with mods 05 GP for DD
  15. #15 Re: Amp power wire help!!!!!
    Its not that little... About 3x2 maybe?
  16. #16 Re: Amp power wire help!!!!!
    swift current,sask.
    Yup, refer to the pic i posted...
  17. #17 Re: Amp power wire help!!!!!
    Cleveland
    Ok thanks I will try it out.
  18. #18 Re: Amp power wire help!!!!!
    I've got two runs of 4 guage and i didn't even bother putting it back in this time... I dont drive through puddles anyways =D
  19. #19 Re: Amp power wire help!!!!!
    swift current,sask.
    Yes yes the grommet itself, i did that too. There is like a rubber plug that goes in that hole too, that is what they are talking about.
  20. #20 Re: Amp power wire help!!!!!
    CT
    Yes I remember when I had to do this. The rubbed plug is a pain to get out unless you grab it with some plyers. I didn't evenput mine back in and it works just fine without. Took a screw drivers and drove it though the plastic cover on the firewall side and then it was simple as pie to push the wire through from the firewall.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  3. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
