Thread: wadda think of this setup?
Results 1 to 20 of 22
  1. #1 Re: wadda think of this setup?
    Apr 2008
    I would suggest getting rid of the two tens, porting the box with the 12s, and replacing the cap with a decent sized batt. The lack of the two boxes will give you more space, less wires, and the batt will definitely be a better option compared to the cap which really doesn't help much.
  2. #2 Re: wadda think of this setup?
    Saraland Alabama
    Quote Originally Posted by captaincheesey View Post
    all a battery is is a bad cap (they store energy, but can't discharge as fast) they are great for key off runtime, but not transients
  3. #3 Re: wadda think of this setup?
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    When I competed in SPL we used Batcaps. Been a few years and I don't even know if they still make them but try looking them up. One of my old team mates had about 8 of them if your interested I'll look him up and see if he still has any.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  4. #4 Re: wadda think of this setup?
    Apr 2008
    Quote Originally Posted by JCG's-GTP View Post
    They do still make bat caps, and are nice to use. I am on a bunch of audio forums and know people who still use them. As to the battery being a bad cap comment, anyone who is serious into audio does not use caps. They discharge too quickly, and store too little power. 1 farad is equal to roughly 1 second of power, nice little demo huh? Look into putting maybe a Yellow top back there instead of the cap and you should be fine. The stock alt is I believe 105 amps? So that, a nice batt up front, maybe a red top, and then a yellow top in the back should hold you over for a while. Batts hold more power than a cap and discharge slower so you can get more power out of them. If you need some good proof here is a link: Click here
  5. #5 Re: wadda think of this setup?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    1)anyone who is serious into audio does not use caps.
    2)So that, a nice batt up front, maybe a red top, and then a yellow top in the back should hold you over for a while. Batts hold more power than a cap and discharge slower so you can get more power out of them.
    1)I guess that means Steve Meade, Dave "Danger Boy" Johnson, Gary Biggs, Micheal Hughes and quite a few other of my friends that I have met over the ears of competing and installing are not serious about audio. Also I guess that by default makes me not so serious about audio.
    2)Putting 2 different designed batteries in without a isolator is horrible advice, in fact putting 2 different sizes and type batts together in any case is not very good advice at all.
    I am not going to comment on which is better a 2nd batt or cap, because I think they should be used in conjuction. As do all the other competitors I mentioned above believe.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  6. #6 Re: wadda think of this setup?
    Saraland Alabama
    Quote Originally Posted by s1795so2 View Post
    what is your opinion on my point of them being similar (only the cap is faster) I am just wondering?
  7. #7 Re: wadda think of this setup?
    Feb 2008
    Nashville
    Have you done MECA before? I met alot that you just mentioned at our world finals one year.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. Timeing a double roller setup???????
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2008, 04:28 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
