Thread: Timeing a double roller setup???????
Results 1 to 7 of 7
  1. #1 Timeing a double roller setup???????
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I remember reading somewhere about timing a double roller setup and that it can be easily screwed up. Since my car has been running kind of crappy ever since I installed all the mods in my sig I was thinking maybe I screwed this up. Can anyone shed some light on this subject?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: Timeing a double roller setup???????
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Well IF you installed it straight up then it is likely to be -2* retarded versus the stock timing set. Seems that the only difference is a little more top end power and a little less low end.
    Reptile just posted about his recent double roller issue.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Timeing a double roller setup???????
    New Salem, ND
    What do you mean straight up? I believe I installed it on both 0* marks.
  4. #4 Re: Timeing a double roller setup???????
    if you lined up the dots, that's "straight up". but because they were designed from an l36 timing set, they are automatically -2* retarded on an l67 setup. not that big of a deal, actually quite good for a powerband up top.
    timing it on your own is a seperate story. i want some people to try it out and post up about their experiences. it would be beneficial to know what you can do with what effects.
  5. #5 Re: Timeing a double roller setup???????
    New Salem, ND
    So cam to crank timing on an l36 is +2* v.s. an l67? Will it be -2* with a JP and a rollermaster?
  6. #6 Re: Timeing a double roller setup???????
  7. #7 Re: Timeing a double roller setup???????
    Wichita, KS
    For the GT's and GTP's just line the dots up, they will both work, and run just fine. Be sure to hand turn the motor over a few times before re installing your valve train to make sure its in perfect time.
    If you want to get really into it, use a degree wheel, but you will find that they are still ok lining the dots up.
    Like said above, the GTP's run even better with a little mechanical cam retardation on the top end.
    ~F~
  1. Those of you with double roller timing chains....
    By Reptile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 11:49 PM
  2. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
