Thread: wadda think of this setup?
Results 1 to 20 of 22
  1. #1 Re: wadda think of this setup?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    1)anyone who is serious into audio does not use caps.
    2)So that, a nice batt up front, maybe a red top, and then a yellow top in the back should hold you over for a while. Batts hold more power than a cap and discharge slower so you can get more power out of them.
    1)I guess that means Steve Meade, Dave "Danger Boy" Johnson, Gary Biggs, Micheal Hughes and quite a few other of my friends that I have met over the ears of competing and installing are not serious about audio. Also I guess that by default makes me not so serious about audio.
    2)Putting 2 different designed batteries in without a isolator is horrible advice, in fact putting 2 different sizes and type batts together in any case is not very good advice at all.
    I am not going to comment on which is better a 2nd batt or cap, because I think they should be used in conjuction. As do all the other competitors I mentioned above believe.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: wadda think of this setup?
    Saraland Alabama
    Quote Originally Posted by s1795so2 View Post
    what is your opinion on my point of them being similar (only the cap is faster) I am just wondering?
  3. #3 Re: wadda think of this setup?
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Have you done MECA before? I met alot that you just mentioned at our world finals one year.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. Timeing a double roller setup???????
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2008, 04:28 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
