First I'm planning on doing the big three with the bat-alt wiring running from the Bat + to the fuse box post then to the alt. My question, is the fuse box post fused? I'll be putting a fuse holder between the bat and the fuse box post but do I need one from the fuse box post to the alt?
(related note) I am mounting the fuse holder on the wheel well by the fuse box but I don't want to drill holes, how else could I mount it? I was thinkin maybe velcro.
And i've read that you should ground your HU other then the factory ground to reduce noise. If I used the factory ground and ran a wire from a bolt on the HU to the chassis it would work right?
Joe
