I can't get the volt drop right now as I took my carpet out due to the "water on the floorboard" problem. I reran all my wires while i had it up and haven't got it all put back together yet.
When I get it all setup ill measure the volt drop. Then I'll put a 4ga cable from my alt to my fuse box and do it again to the same song with the same volume just for the hell of it, can't hurt nothing, if it don't do anything I'll take it off, it helps even a little I'll keep it on.
Few more question for you two.
(1) My small amp is cheap (maybe $30, I'll be replacing this when I get the money) would it be enough to cause my dimming seeing how small it is? (I had just my sub amp hooked up for a while before and it never dimmed.)
(2) What is the average draw from an amp on the remote wire? or do you think a relay is necessary on a remote wire? (I'll check mine when I get it all setup)
