ok since your getting half baked answers here, that wire under your hood is wrapped around it to sense the pulsing. Some units did that as one option instead of going to a injector or coil or pcm wire.
To check for a system drop your bottom fabric cover and look to see if there is a black or purple module under there usually you will see a bunch of colored wires going to it. Factory wires and wrapped in black tape. So it should stand out. If nicely done it will be more hidden and you might have to pull down your plastic panel under the column.
Follow it to the unit. Once you find it you can see if there is a name/ model on it to possibly get remotes and install manual.
