Thread: do I have a remote start or what??
Results 1 to 20 of 28
  1. #1 do I have a remote start or what??
    Donating Users kind153's Avatar
    Pittsburg, KS
    I have a little red sticker under the hood, saying that it has a remote start installed and can be started anytime. but I wasn't given any remote other than factory ones at the time of purchase.
    It's 98 GT.. I'll try to post the pic of the sticker soon.
    How do I find out if it actually does have the remote start module(?) in it?
    Can I buy a remote only and sync it with the module (if exists)??
    I kinda tried to look inside when I opened my driver side while replacing my DIC..but no luck without knowing what I'm looking for;
    Thanks!
  2. #2 Re: do I have a remote start or what??
    Jan 1970
    Maquoketa, Iowa
    Mine has a toggle under the hood that when the hood closes, it hits and allows it to start when the hood is closed. Also has a reset switch in the cubby left of the steering wheel, led light that will flash...
  3. #3 Re: do I have a remote start or what??
    Pittsburg, KS
    Here are the pictures of the "signs".
    1.
    2.
    Anyone??
  4. #4 Re: do I have a remote start or what??
    SE Level Member habeba86's Avatar
    Elmwood/Peoria Ill
    More than likely yes. The red wire prolly ran to the tach wire which is under all the ignition module on the left in the bottom pic. Is the red wire not hooked up anymore?
  5. #5 Re: do I have a remote start or what??
    Pittsburg, KS
    Quote Originally Posted by habeba86 View Post
    That'd be my next question. How do I know if it's hooked up or not? I traced it and I lost it behind the brake fluid reservoir (which goes to right side of bottom picture.) I'll try to see if it goes to the ignition module.
    But aren't there supposed to be a module or something that receives/controls remote start signal?
  6. #6 Re: do I have a remote start or what??
    Pittsburg, KS
    The red wire is connected to #1 wire.. what does this mean?
  7. #7 Re: do I have a remote start or what??
    maryland
    I have one on my truck that works with the factory key fob. To start the truck all i have to do is hit the lock button three times.Hope that helps
  8. #8 Re: do I have a remote start or what??
    Pittsburg, KS
    Quote Originally Posted by powersmokin View Post
    Very interesting! I'm gonna try it tomorrow morning.
    Thanks!
  9. #9 Re: do I have a remote start or what??
    Pittsburg, KS
    didn't work
  10. #10 Re: do I have a remote start or what??
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    number one plug wire or pin #1 in the ignition control module , definately shouldent be hooked up to the plug wite that would fry any remote start on the planet thats like 50,000 volts right ? if it is hooked up to the plug wire its probably fried anyways , unless its a cheap one and its a sense wire like a timing light thing that detects when the motor is running , but most of the times remote starts are hooked up under the drivers side dash and tied into the main ignition harness , with 5-6 thick 12 ga wires and a black box and usually a few relays
  11. #11 Re: do I have a remote start or what??
    Pittsburg, KS
    Quote Originally Posted by eddie97gt View Post
    it's spliced into #1 plug wire.. some type of sensing purpose i was guessing.
    Not,,slightly off the topic, rather moral,
    if I go to a remote start shop to check to see if i really have one or not, how much do I have to tip that person??
  12. #12 Re: do I have a remote start or what??
    Pittsburg, KS
    anyone??
  13. #13 Re: do I have a remote start or what??
    May 2008
    ok since your getting half baked answers here, that wire under your hood is wrapped around it to sense the pulsing. Some units did that as one option instead of going to a injector or coil or pcm wire.
    To check for a system drop your bottom fabric cover and look to see if there is a black or purple module under there usually you will see a bunch of colored wires going to it. Factory wires and wrapped in black tape. So it should stand out. If nicely done it will be more hidden and you might have to pull down your plastic panel under the column.
    Follow it to the unit. Once you find it you can see if there is a name/ model on it to possibly get remotes and install manual.
  14. #14 Re: do I have a remote start or what??
    Pittsburg, KS
    Quote Originally Posted by Street Dreams CC View Post
    Thanks for your reply. So, by the presence of 'sensing wire', is it safe to think there IS one? I pulled down the panel under the column when I was installing digital DIC, and there wasn't anything particularly standing out, but I will check again. Thanks!
  15. #15 Re: do I have a remote start or what??
    May 2008
    again
  16. #16 Re: do I have a remote start or what??
    Pittsburg, KS
    I went there, but don't seem to able to find it. Here are pics that I took:
    Maybe I'm stupid-_but nothing stands out except spliced wires(?)
    Any comments is appreciated.
    MK
  17. #17 Re: do I have a remote start or what??
    Pittsburg, KS
    anyone??
  18. #18 Re: do I have a remote start or what??
    CT
    The spliced wires look like it has remote start. Follow the wires and there will be a box under the dash.
  19. #19 Re: do I have a remote start or what??
    Pittsburg, KS
    Quote Originally Posted by pontiac88 View Post
    please elaborate,, where exactly is 'under the dash' ??
    I realized that I haven't checked passenger side, can it be there?
  20. #20 Re: do I have a remote start or what??
    CT
    Usually its on the driverside. If you look up from the floor you should see it. If you follow the wires that are spliced you should find the box. They normally dont try to hide it. Looking at your pics, are there wires spliced together? Kinda looks like the splice packs are there but are not putting two wires together.
  1. Does my car have Remote Start? -- Solved
    By SyriusX in forum General Tech Discussion
    Last Post: 12-01-2010, 06:30 PM
  2. problems with remote start
    By fernando23 in forum Introductions/Noob Questions
    Last Post: 06-11-2009, 11:04 AM
  3. Remote start on GP
    By Freebeer187 in forum General Tech Discussion
    Last Post: 04-12-2009, 07:30 PM
  4. DEI remote start
    By NightriderGT2000 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2009, 08:18 PM
